Air intake
Old Apr 19, 2013 | 06:14 PM
onetwothree's Avatar
Air intake
For the ge jazz you just need an air intake which has a point for the MAF sensor to fit in and it's all good yeah?
Old Apr 20, 2013 | 02:20 AM
loudbang's Avatar
the new connector HAS to have the correct size inside to match the stock one or you will get MILs.
Old Apr 20, 2013 | 08:26 AM
I dot get what you mean, so inside where the MAF sensor sits its built for certain MAF sensors so if its not the correct one it won't work?
Old Apr 20, 2013 | 04:24 PM
13fit's Avatar
the TUBE size must match oem.
The sensor calculates airflow based on that specific tube section area.
With it smaller, it will run very rich, even if the difference is small.
With it larger, it will run very lean and cost you a motor at worst case
Old Apr 20, 2013 | 04:56 PM
So if I was to find a intake that has the right fit it is usable? Thanks for the replies
Old Apr 21, 2013 | 02:10 AM
loudbang's Avatar
Yea the part right where the MAF sensor is put into. The inside diameter right there has to be the same size as stock. There is one that everybody has good luck with on GEs if you can find one down there. The PRM intake. There are some threads on it.
Myxalplyx
102
Apr 30, 2018 06:07 PM
Destiny
Dec 8, 2017 04:20 PM
TxMedic
14
May 13, 2015 02:02 PM
cdninsw
Feb 20, 2014 05:33 AM
bboozeman
Aug 31, 2007 09:40 PM
