Wheel Stud thread patterns?
Old May 23, 2013 | 01:25 PM
236GFX's Avatar
I'm looking to pick up a decent set of wheels (Honda; Take-off wheels) from a friends Teg' (4x100)
Does anyone know the thread pattern and are they studs/bolts or nuts?
I haven't even popped the wheel trims off yet for fear of cracking them.. The seller had some OE Honda ones re-fitted before I purchased my GD
If I grab these from my friend I need to know what fixings to pick up. If they're nuts that fix them to the hub I want to order some nice Tuner studs like "BLOX" etc.
Anyhow my Question is; Does anyone know the Thread-pattern, and are they studs or nuts to fix them to the hub?
Thanks
EDIT:: Just did a little research and they're Nuts that have to fix them onto the hub (Hub has protruding Studs) so what are the Nuts Thread pattern?
Old May 23, 2013 | 02:06 PM
maybememories83's Avatar
You want 12x1.5 lug nuts
Old May 23, 2013 | 02:10 PM
Wanderer.'s Avatar
You'll have to use Honda lugnuts or ball seat lugnuts with those wheels (the Integra wheels). They are OEM Honda wheels?
M12x1.5 is the pitch. There's a few colored sets available online that work with OEM wheels. There's a ton of chit-chat on here talking about them if you search around or use Google.
Old May 23, 2013 | 02:17 PM
236GFX's Avatar
Yes these are the wheels;
Thanks!
I'll take a look at my local auto-supermarket for them!
Old May 23, 2013 | 02:21 PM
Sorry to hijack, but does the Fit require ball seat lug nuts no matter what rims are used?
Old May 23, 2013 | 02:45 PM
gawa's Avatar
I think the OEM Integra Type R wheels are 4x114.3, whereas the Fit/Jazz is 4x100. If that's the case, then they won't fit. Just a heads up.
No, it depends on the rims. Most OEM rims are ball seat, most aftermarket rims are conical seat.
Old May 23, 2013 | 03:26 PM
Wanderer.'s Avatar
Yes to both of these. You'd need a 4x114.3 to 4x100 adapter or would need to change the hubs with something that was 4x114.3 that will work, what hub would work on the Fit I haven't the slightest clue.
Old May 23, 2013 | 07:59 PM
236GFX's Avatar
Ok well that saves me the trouble of driving 30mins to take off one wheel to discover they are the wrong fitment!
I'll take a look for 4x100 Honda wheels at my local scrap yard
Old May 24, 2013 | 11:43 AM
mahout's Avatar
The diameter of the lugnut is 12 mm. It is not 1/2"
The pitch is indeed 1.5 mm; do not try to use SAE nuts. Most Honda OEM are ball seats; most aftermarkets, since Honda is not the only brtand that uses 4x100 stud pattern, are conical.
When you looking for scrapyrad wheels be aware that the center hole needs to be 68 mm and tyhe offset no more than 53 mm or less than 42 mm. And BE SURE THE WHEEL SPOKES WILL CLEAR YOUR CALIPERS !
Old May 24, 2013 | 11:50 AM
236GFX's Avatar
Im going to see a set of Volk TE37's and a set of TE37V's at a friends auto supermarket.. Got to get over there soon. 15s are what I want, on some Coil'ies and rolled arches..
Old May 24, 2013 | 01:25 PM
Wanderer.'s Avatar
Center bore is 56.1mm for all 4x100 Hondas AFAIK
Old Jun 27, 2024 | 08:48 AM
Pseast's Avatar
Anyone know what the standard stud length is for honda fit gd? I have 10mm and 20mm spacers. Trying to find the correct studs for em
subicraze
Jun 1, 2015 06:16 AM
Pumpkin
Nov 8, 2014 12:03 PM
annunC8
Feb 14, 2013 09:47 AM
IstayFitted
Jul 22, 2008 09:18 PM
divisionerror
May 15, 2006 12:16 PM
