I-dsi Turbo question
Old Jun 24, 2013 | 11:59 AM
jms's Avatar
jms
I have a few questions regarding turbocharging the L13 (jdm) I-DSI engine... I have spent quite a while searching the forum and google though I can't find much relevant information on IDSI turbo charging.
Someone I spoke to about this said 180 bhp was possible on the 1.3 on standard internals? Though I have nothing to back this up with as the only IDSI engine I have seen is the 1.5, although I did read a post from 2006 on this forum stating there is no point turbocharging the idsi engine.
Originally Posted by anjingbalap
well.. 1.3L is an i-sdi engine.. according to topfuel and HKS i-sdi is no point to be put a turbo charge u might try supercharger.. but u need to spend money for internal upgrade (piston and stuff)
its because i-sdi is design for fuel economy not performance.. and it have 2 spark plug on i-sdi engine is mean when u turbo charge it.. A/F ratio will be very2 Lean therefore Lean Mixture can damage ur engine tryingor blow sumting.. so u should consider it again...
Quite confusing as there seems to be allot of contradiction when to find certain info online
But... My main questions are:
• I-DSI 1.3 turbo possible?
• What would be the best turbo for quick spool and power delivery?
• What is a safe amount of boost on the I-DSI engines?
• Would dual spark cause any problems with mapping etc?
• Does anyone have a ROUGH bhp or whp figure that could be achievable and relatively safe?
Hopefully someone can help!
Old Jun 25, 2013 | 04:43 AM
loudbang's Avatar
Yes it is possible. Beware because the ISDI is built to run WAY LEAN compared to the VTEC engine to get better fuel mileage. Basically it is the same engine with a different head so any HP figures for the 1.3 would be compareable with the 1.5 BUT remember it is less cc so reduce you goals a bit from what they get from the 1.5.
Old Jul 3, 2013 | 03:47 PM
TPColgett's Avatar
Your main problem is tuning.
Decide/find a way to get detailed engine data logs and how to tune your Fuel and Spark tables, as well as how to compensate for boost at the MAF sensor.
It's in the "2nd gen" sub forum but the thought process and info here still applies:
https://www.fitfreak.net/forums/2nd-...rbo-build.html
Old Jul 4, 2013 | 01:13 AM
loudbang's Avatar
ISDI don't have maf sensors.
Old Jul 26, 2013 | 11:13 PM
Revjazz's Avatar
i will planning to bolt on my idsi l13a 1.4 idsi ..i now hard to fine out turbo turbine suit to idsi engine. my planning turbo tdo4l gsr or ct9 turbo from toyota starlet ep81 .. or gt20 from garret turbine..
My question .. how many cc injector stand for l13a idsi.
siguy
Dec 21, 2015 06:13 PM
clanbuster
Mar 9, 2010 06:20 AM
xorbe
May 7, 2008 07:40 PM
p11wrg
14
Dec 27, 2007 12:08 PM
southwilrise87
Nov 10, 2006 04:45 PM
