Will these fit the front of a gd?
Old Jul 19, 2013 | 10:49 PM
Maty J's Avatar
looking at new front rotors for my gd, (oem is 240) these are 239mm 4 bolt, these look right on the money? Thoughts?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180611846779&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
Old Jul 19, 2013 | 10:56 PM
Maty J's Avatar
for that matter, will almost any 240mm rotor fit?? new to this
Old Jul 19, 2013 | 11:07 PM
solbrothers's Avatar
why not just get some rotors that are made for your car?
Just go to your local parts store and get the correct rotors. You don't want/need slotted/drilled/dimpled/etc rotors.
Old Jul 19, 2013 | 11:25 PM
13fit's Avatar
It will bolt onto your front hub, but most likely the hub of the rotor is different, causing fitment issues with your front caliper.
Like above, I recommend getting the correct rotors for your car. Ebay, local partsstores, and online shops will all have the correct parts. Get at least a step above the cheapest. The cheapest rotors usually warp or wear faster. Its worth spending 50+ on the front pair
Old Jul 20, 2013 | 01:23 AM
loudbang's Avatar
Short answer NO they will not. The front and rears are different on models that come with discs on the rear.
Old Jul 21, 2013 | 01:25 AM
loudbang's Avatar
If you can find a photo of the front discs you will see there is only 3/8s or 1/2 inch where the hub part extends from the rotor itself. But if you look at that rear rotor you can see it sticks out a couple of inches at least. They are not even close.
Doesn't this site offer fronts if they are selling rears?
Vash
Dec 4, 2017 07:24 AM
pmartensen
Jan 11, 2013 06:08 PM
Colincarguy
Aug 5, 2012 06:28 PM
andrewmanley
Sep 12, 2009 11:53 AM
p1driftfiend
14
Dec 7, 2008 10:51 AM
