STOCK H/U With Amp N Sub
Old Aug 13, 2013 | 06:36 PM
Wafulz's Avatar
Talking STOCK H/U With Amp N Sub
hi there like title says is anyone running it if so what will i need thanks for all ur Opinions
Old Aug 13, 2013 | 07:23 PM
krunk13's Avatar
I am. Its ok not great. the Fits HU modifies the bass and attenuates it past the range that it feels the stock speakers ( which you have to tap into) can handle.
Old Aug 13, 2013 | 07:26 PM
krunk13's Avatar
try one of these. Its supposed to correct the HU attenuation and increase the voltage.
AudioControl LC2i 2-channel line output converter for adding amps to your factory system at Crutchfield.com
Old Aug 13, 2013 | 07:43 PM
Wafulz's Avatar
would it work with my H/u its the oem nav
Old Aug 13, 2013 | 07:49 PM
krunk13's Avatar
Yeah its super simple too. just find the wiring diagram and tap into the rear speakers as inputs for signal to the sub and there should also be a +12 and GND to power the LC2. From there you run a wire from the battery to your amp and sub and use one of the rear tiedowns for a ground. super easy
Old Aug 26, 2013 | 02:42 AM
djcrawf777's Avatar
like he said it sounds ok with the factory HU. From a technical perspective it sounds like the roll off begins at 40 hz and then 30 hz falls straight down. I have used countless methods of reintroducing those subbass frequencies like selectable bass boost and amp tuning but to no avail. There is a certain song I listen to by an artist named Dwele call "Dodgin' your phone" and there is a bass note that I could hear on previous systems but in the Fit it is non existent.....even just a little bit. everything else sounds ok though
Brentw101
Sep 6, 2018 03:55 PM
FyrFytr
Apr 10, 2012 12:46 PM
mdsniper7
Feb 18, 2012 07:00 PM
WhiskeySix
May 17, 2011 08:19 PM
setter11
Feb 10, 2009 12:59 AM
