Painting Rims
Old Aug 15, 2013 | 08:16 PM
WangLung's Avatar
Painting Rims
So I've got a set of NT03's and I am in the process right now of prepping them for paint. I've got two questions that I wanted to ask. What kind of primer, paint and clear should I use? (Paint gun, not rattle can) And also how much of the rim should be painted? (The entire rim every nook and cranny or just the front/face up to the bead and the inner barrel leaving out the portion thats filled with air)
Thanks in advance guys!
Old Aug 15, 2013 | 08:48 PM
13fit's Avatar
Ive always used rattlecans for the cheapness and good results when applied correctly.
If the rims are scratched up use a filler primer
wet sand the rims until everything looks smooth
then I just pick a color and texture and away I go.
I would tape off the tire itself, and use a brush to clean every nook and cranny that you can see.
I wouldnt worry about the back of the rim unless the rim design allows you to see the inside edge
Old Aug 16, 2013 | 08:30 AM
jnesselroad's Avatar
just remember prep is the name of the game. you should spend about 3 times longer getting the rim ready to paint than it actually takes to shoot it. the stage RIGHT BEFORE you paint, make sure you use some sort of paint prep, like acetone, then I would still go over it with a tack cloth. You can always go back and wet sand imperfections out, but it's a lot easier to stop them in the first place.
Big_tr33
Jul 9, 2015 11:20 AM
Eggroll Shogun
Jun 26, 2014 12:23 PM
MTLian
Dec 3, 2013 11:02 AM
sh00k
Jan 21, 2012 07:38 PM
Luichenwai
Sep 15, 2007 09:36 PM
