Looking for the Brake fluid change thread?
Old Oct 24, 2013 | 10:17 AM
P-Fit's Avatar
The 3 (4 actually) years are here and I'm feeling like this should be done asap.
Directions to the related Thread would be very soo appreciated
Any help?
Old Oct 24, 2013 | 11:20 AM
Black3sr's Avatar
I had mine done at dealer along with brake service, wheel alignment and wiper inserts for $256
Old Oct 24, 2013 | 12:07 PM
Rampo's Avatar
A little tip on searching these forums. Instead of using the built in search function, go straight to Google and precede your search with "fitfreak". I always seem to get better results this way.
Check out this thread on brake bleeding: https://www.fitfreak.net/forums/fit-...tml#post909875
Old Oct 24, 2013 | 03:27 PM
BurntZ's Avatar
Old Oct 24, 2013 | 03:54 PM
Triskelion's Avatar
Any help?
https://www.fitfreak.net/forums/2nd-...ill-bleed.html
Old Oct 24, 2013 | 08:57 PM
P-Fit's Avatar
|Nice! thanks for the suggestions
Got a quote for $65 from my local Honda dealer.
Time to weigh the options!
Old Oct 25, 2013 | 03:50 AM
loudbang's Avatar
If you have a manual trans do the clutch fluid at the same time.
Old Oct 25, 2013 | 02:48 PM
Spacecoast's Avatar
Hand Operated Vacuum Pump | Lab
This is what I use...I've had one for probably 20 years and it works like new. Its done many brake bleed jobs, and its easy to use. They ususally come with assorted hoses, fittings and a catch container. Can usually find one at an auto supply store that contains the correct type catch container to do brake jobs.
QuanticBeat
May 27, 2024 10:19 AM
sailorman2439
Oct 2, 2016 04:43 PM
tietack
Nov 6, 2011 09:09 AM
InSaNehb
Jun 24, 2011 10:54 AM
AppleMac*Fit
Nov 14, 2010 01:40 PM
