Replacement key costs?
Old Mar 6, 2014 | 10:11 AM
demouser's Avatar
What are you paying for a replacement fob with the buttons?
What are you paying for a replacement valet key?
Does the Fit come with a valet key?
Our local dealer (Pauly Honda) said to make a replacement key, bring the vehicle in along with all the keys you have. $130 for a new 2-button fob.
Old Mar 6, 2014 | 10:13 AM
D429302's Avatar
That labor price is gonna be about right. Half the cost is to program the key, incase you were wondering if your getting ripped off or not.
Old Mar 6, 2014 | 10:19 AM
demouser's Avatar
That sounds about right. $60-ish for the key + the minimum 1 hour of shop labor. I heard some guys were paying <$100, but maybe the labor rate is lower where they live.
Old Mar 6, 2014 | 10:31 AM
Hootie's Avatar
Price varies from dealer to dealer but price sounds about right. Fits do NOT have a valet key of any sort, just a basic valet-like key for the early Base models and a black 3-button (Lock/Unlock/Panic) Keyless Entry key for early Sports (and all models in the later years).
You don't absolutely NEED to bring all your keys if you are simply adding one additional key to your car (a tech that knows what they're doing can simply add 1 key without affecting the others)... unless of course you lost one, then that lost key will need to be deleted from the car (the lost key will still open the doors mind you).
Old Mar 6, 2014 | 12:06 PM
D429302's Avatar
That is absoloutly correct. You can also buy a "t5" stamped key which is a lot cheaper and does not require programming. I cant remember if t5 keys can come with the keyless entry or not but i can check if u want.
Old Mar 6, 2014 | 09:32 PM
n9cv's Avatar
I had another intelligent key with fob made a few months bock at a local locksmith. It cost me $65. He took less than 5 minutes to cut the key and another 5 minutes to plug in to the car with his laptop and program it.
I was is and out in 15 minutes.
Old Mar 7, 2014 | 03:52 PM
demouser's Avatar
I'll have to check local locksmiths. People around here recommended the Ace Hardware as an "expert on car keys". Ace said "we can only make a valet key, but it won't start the car." So how is that a valet key then??
Old Mar 7, 2014 | 07:02 PM
DaveFL's Avatar
Valet key of sorts, it can operate the locks including the steering wheel. Can be used as key for travel while towing or to get you into the car if you keep a spare inside. Probably wrong term to use as usual valet key can start and run the motor, while this one without programming will start it and the computer shuts it down in 30 seconds. Salesman promised an extra key and after the sale said he couldn't do it until I said I only need it to unlock steering. Make sure you get stuff in writing, including the promised free oil change that didn't get recorded at the dealership service department.
Old Mar 11, 2014 | 03:04 PM
The Kev Master's Avatar
I've got a similar question for me 13 Fit Sport. I visited my local lock specialist and they said I need to have the right alphabet on the key before they can program it as the chip needs to match. I've seen some similar original Honda keys that have the P alphabet while mine is L.
Does anyone know what this entails?
Old Mar 14, 2014 | 11:50 PM
Threw_A_Fit's Avatar
$150/key... which doesn't include ½ hour of programming, depending on shop labor, assume around $200/key
Old Mar 15, 2014 | 12:19 AM
Mine was $70 + tax for the key and $60 to program.
Old Apr 23, 2014 | 12:40 PM
davidnyc's Avatar
Tow warning.
Do not tow a car in park, can damage tranny. (duh) Valet key will open car but you have to pop the plastic latch next to shifter and insert key to overide lock on putting car in Neutral. FYI.
Old May 8, 2014 | 03:28 PM
phogroian's Avatar
I bought three keys from Bernardi Honda last week for under $40 each, and my dealer (Bill Page Honda, VA) cut and programmed all three for $83, so it came to about $65 per key.
Old May 14, 2014 | 01:19 PM
2010FitInSK's Avatar
I'm pretty sure that's not true. An unprogrammed key will turn the key to "on" which is all you need in order to move the gear shift out of "Park". You do NOT need to start the engine to do so. Just turn the key to "ON", step on the brake, and move the gear shift.
Old Jun 15, 2014 | 05:53 AM
DWils's Avatar
Any update on this?
Joe Castanza
Jan 12, 2021 11:25 AM
RixAE86
Feb 21, 2019 01:43 PM
User1
Sep 12, 2018 05:48 PM
SilverEX15
Sep 28, 2015 09:03 AM
csteve21
Sep 2, 2009 06:54 PM
