Drum brake noise after replacing drums
Old Apr 23, 2014 | 09:47 PM
XxPuNTeRxX's Avatar
Unhappy Drum brake noise after replacing drums
Hi,
I recently replaced ONLY drums while changing wheels with CENTRIC Part # 12340009 C-TEK Standard Brake Drum from RockAuto.com
The noise :
I didnt initially clean the rear brakes at all. They were quite dirty. So I cleaned them with brake cleaner after driving a good 200kms in the city.
The are still noisy.
Any suggestions?
Thanks !
Chris
Old Apr 24, 2014 | 10:44 AM
Wanderer.'s Avatar
Did you adjust the shoes?
Old Apr 24, 2014 | 10:46 AM
XxPuNTeRxX's Avatar
No is there a guide on how to do that or should I just put in a new set ?
Old Apr 24, 2014 | 11:54 AM
Wanderer.'s Avatar
There should be a star wheel that you turn to move the shoes in and out. If you just replaced the drum only, the shoes need to be pulled in, as they automatically adjust as the drum gets worn. Your new drum is not worn at all and the shoes are probably auto adjusted to the old worn drum.
IDK if that makes sense?
Should look something like this:
HowStuffWorks "How Drum Brakes Work"
Though I can't find a Fit specific picture.
Old Apr 24, 2014 | 12:57 PM
XxPuNTeRxX's Avatar
Yeah makes sense thanks so much i'll try tomorow eve
Old Apr 30, 2014 | 06:16 PM
XxPuNTeRxX's Avatar
Done adjusted and works fine
Old Apr 30, 2014 | 06:20 PM
Wanderer.'s Avatar
Excellent! Glad you got it sorted
Old May 1, 2014 | 05:23 AM
Black3sr's Avatar
Curious why replace drums and not the shoes? If anything shoes should be worn out first and drums could likely just be turned.
wmo168
Mar 29, 2018 09:50 AM
gsarmedic
Aug 22, 2013 01:37 AM
EXCellR8
Jul 22, 2013 01:43 AM
.eL
Jun 25, 2010 01:41 PM
Elle Navorski
May 4, 2005 11:16 AM
