Cleaning EGR Valve Passages
Old Jul 13, 2014 | 05:13 PM
Mynodha's Avatar
Hey guys. On another thread I was mentioning cleaning the EGR valve to remove hesitation. It seems the other models (Accord for example) are better setup to clean the EGR passages. However the Fit does no have a good way of cleaning. It seems the port goes through the head. Am I correct that the only way of cleaning the EGR passages is to remove the head? I think I'd rather sell the car if I need to remove the head.
Any help would be appreciated. Thanks!
https://www.fitfreak.net/forums/1st-...itation-2.html
Old Jul 13, 2014 | 07:03 PM
ikutoisahobo's Avatar
Maybe your problem isn't the EGR valve. You say you have hesitation, and hesitation is usually a symptom of coil packs going bad, or you need valve adjustment.
You can clean the EGR valve itself, and see if it makes a difference, going all the way as to cleaning the ports themselves is a pretty big job.
Old Jul 13, 2014 | 10:06 PM
13fit's Avatar
remove egr valve and clean it. remove the egr pipe on exhaust side, and spray brake cleaner in it.
it will take awhile to do it
Old Jul 13, 2014 | 11:00 PM
doctor J's Avatar
Stuck open EGR causes hesitation and will set the DTC (sensor will not be "at home" when EGR commanded off
Old Jul 13, 2014 | 11:13 PM
Mynodha's Avatar
Thanks guys for the help. I'm not ruling out ignition problems but I've had a lot predictable issues with the EGR. My EGR was clogged at around 80k miles. I also accidentally shot coolant into the passage a while back. With my last battle I was getting serious bucking when going uphill... I opened the hood and wiggled the connector for the EGR and was better. So I've had some bad history with the EGR. I believe the EGR is working but I suspect the passages may be blocked from the coolant mishap.
I am getting a better understanding of how everything is working. The typical configuration for a honda has an access panel so the ports can be cleaned. I believe the fit has access too but nobody has discussed it yet. Tomorrow I will take a look at this access panel. I believe it is for the EGR passages...
If picture doesn't show, click the link.
Old Jul 15, 2014 | 06:18 AM
Mynodha's Avatar
Cleaning 2008 Honda Fit EGR Passages:
I accidentally said Facebook instead of YouTube but you get the idea. I just realized how terrible the quality is on that video. I'm not sure what happened. It looked great before but now it looks bad.
Old Jul 16, 2014 | 03:36 AM
Mynodha's Avatar
Well my hesitation is still there. Thanks everyone for your recommendations. As I said in the video, I'll be replacing the coil packs next.
I think the project to clean the passages was a success though. We should rule out easy and free possibilities before spending big money. This project was easy and free! Also I learned something which was not on youtube or this forum. Can't beat that.
When I get the coil packs I'll let everyone know.
Old Jul 16, 2014 | 03:42 AM
Mynodha's Avatar
Both situations may cause the hesitation. If the EGR is clogged (stuck closed), it will cause hesitation when the car is accelerating or going uphill(under a load). If it's not accelerating, it may cause hesitation if the EGR is stuck open. It all depends on what the engine is expecting and not getting.
Old Jul 16, 2014 | 11:24 AM
Marrk's Avatar
Good info.
Old Jul 16, 2014 | 06:35 PM
Jazzyman's Avatar
Look forward to hearing the outcome of the coil pack renewal.
I have a very similar problem, mine seems worse when the engine is warm. Are you going to replace the 8 coil packs?
Old Jul 16, 2014 | 07:09 PM
Marrk's Avatar
Eight might be overdoing it since there are only four cylinders.
Old Jul 16, 2014 | 08:26 PM
Haha, I believe he has the iDSI engine, 8 spark plugs = 8 coils
Old Jul 17, 2014 | 01:25 AM
Marrk's Avatar
I stand corrected.
Steven Hung
16
Feb 17, 2019 03:42 AM
codenamezero
Sep 21, 2016 08:23 AM
averona
Nov 12, 2014 01:30 PM
Fit of RAGE
Sep 12, 2007 02:47 AM
Darellbrownnose
May 18, 2005 11:20 PM
