Loud whining noise at 30mph
Old Jul 17, 2014 | 12:06 PM
eigger19's Avatar
Hello all... i just recently bought a 2009 Honda Fit Sport with AT. I love the car except for the loud whining noise that starts at 30mph.. i did some research and it looks like its the torque converter issue.. does anyone have the same problem?
Old Jul 17, 2014 | 03:12 PM
Steve244's Avatar
Any links? I don't doubt you but I haven't read about whining noises or torque converter problems here (or elsewhere) and I'm OCD. I think one person had theirs replaced under warranty here, but I'm not sure of the diagnosis.
The torque converter locks in all gears (makes a physical connection). It's a fluid coupling, not gears, so I don't think it can whine. It does make some funny noises that appear to be solved by a simple ATF drain/fill. I would characterize these as fluid rushing under pressure (some say it sounds like a grinding noise) and it only does it for a second when shifting from 2nd to 3rd under light throttle.
I'd keep looking for the source of the whine. Does it happen at other times than 30mph? does the pitch change with car speed or engine speed?
Old Jul 17, 2014 | 03:27 PM
eigger19's Avatar
The noise starts at 30mph and continues, the sound does not change even if I go faster than 30mph.. it only goes away when i go below 30mph.. maybe ill try to do a ATF flush...
Old Jul 17, 2014 | 06:48 PM
Steve244's Avatar
I'd rule out other causes. i.e. tires, wheel bearings, alternator, a/c compressor, serpentine belt idler. Whining doesn't sound like transmission issues. Check the ATF dipstick for low fluid.
How many miles?
Old Jul 18, 2014 | 05:32 AM
DWils's Avatar
My car used to have the same problem, but at all speeds. It took me a while to figure out what the cause was, but after a while I realized it was my whiny wife. Divorce solved that problem and there hasn't been whining in my car since!
Old Jul 18, 2014 | 06:16 AM
BrianKearsey's Avatar
Old Feb 11, 2023 | 02:01 PM
brytarroza's Avatar
May i know what is the cause of the sound shifting to 3rd gear.
may i know what is the cause?
sandz
Apr 23, 2014 09:06 PM
rockangelz
Nov 23, 2012 02:09 PM
mrxchris
May 29, 2012 07:50 PM
rhyneba
Nov 24, 2009 07:45 PM
thedeadpoet000
Aug 27, 2007 08:54 PM
