2011 Fit windshield wiper motor
Old Aug 6, 2014 | 03:30 PM
marinewonder's Avatar
Hello,
Wife had a bump that cracked the wiper motor.
I was able to fix it mechanically and it tests fine under direct 12v (spins, suctions, etc).
But it's not working when its all connected.
Does anyone have a segment of the schematic that shows the wiring?
1) I see no voltage on the disconnected wires when I pull on the wiper/washer engage lever with the car on or accessory-on at ignition. I would expect to see 12v here when I pull.
2) When all is off, both wires seem shorted to chassis ground, which is unexpected. Or is that normal due to some relay?
3) The fuse, I believe it's the blue 7.5A fuse, is not blown. I would expect it blown if the wires were stripped/damaged and touching chassis ground.
Any ideas?
-MW
SusyZ
Jun 7, 2019 07:08 AM
Edison Carasio
May 4, 2015 10:02 PM
bascombb
Feb 26, 2015 06:27 PM
strmslvrfit
Jan 7, 2015 11:17 PM
R8EDXXX
Jul 11, 2005 09:18 AM
