TB boring... anyone do it?
Old Aug 14, 2014 | 08:40 PM
Rollerboots666's Avatar
I know this has come up in conversation before on FF but has any pulled the plug and tried boring their TB? Some mentioned Maxbore.com throttle body boring service and repair but I haven't heard feedback from anyone on FF. Curious to hear the results.
Old Aug 14, 2014 | 09:28 PM
kylerwho's Avatar
spoon fed
There are a few people on here that have it done. JL is one guy I believe had it done.
I see this about as useful as getting an electronic throttle controller since the engine cant use more air unless you are running decent boost numbers.
Old Aug 14, 2014 | 09:36 PM
The electronic throttle controller is fun and useful that I have noticed. The downfall is when you get mods and AutoX with it. At max Performance on the ETC it can be to much in the turns.
I'm sure it with some manifold porting it would help.
Old Aug 14, 2014 | 10:42 PM
TPColgett's Avatar
It's also been said that a R18 TB will bolt on and is supposed to be plug and play. That's a 55mm vs our 50mm. Again though, unlesd pushing enough air for 200+whp or so on boost, it's not a necessity lol
As far as I have read on basic TB theory, you want the SMALLEST possible sized hole that still flows enough/as much air as your head/cam package can pump.
Old Aug 15, 2014 | 04:05 AM
kylerwho's Avatar
spoon fed
I'm actually second guessing myself because isn't our manifold a dual plenum design? Which if that is the case then air inlet sizing won't matter at all.
Old Aug 15, 2014 | 01:16 PM
TPColgett's Avatar
Dual plenum?!
Not like these at least : Dual Plenum Intake Manifold - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old Aug 15, 2014 | 06:15 PM
kylerwho's Avatar
spoon fed
No not really. I was looking at my spare oem manifold and there is a plastic divider inside making me think it is a dual plenum designed for second harmonics.
If someone has more knowledge on this it would be great.
royalflush313
Mar 9, 2010 06:55 PM
modfit669
Dec 27, 2009 03:24 AM
amsyl
Dec 16, 2009 06:26 AM
da9r00d
Jul 21, 2009 01:24 AM
Chikubi
114
May 22, 2009 10:26 PM
