2013 Honda Fit - Gear shift indicator light, how do you change it??
Old Aug 23, 2014 | 08:35 AM
stacey88s's Avatar
I need to change out that light, and have have been searching online with no such luck on how to get to the bulb.
I have an older Civic that I am able to pop the area open easily to get to the bulb, but for the life of me, I can't figure out or find out how to get to the Fit's bulb.
This is for an automatic.
Old Aug 23, 2014 | 10:43 AM
Steve244's Avatar
Are you talking about the floor-shifter? I don't think it's illuminated (at least it's not on an 09 Base).
Old Aug 23, 2014 | 04:09 PM
stacey88s's Avatar
Sorry, is this area called something else?
The light behind the P R N D S
Old Aug 23, 2014 | 04:46 PM
xxryu139xx's Avatar
look at collegehillshonda and pull the pdf/video on how to install the OEM armrest. It will show you how to pull the center console/shifter. from there the oval with the gear letters will be exposed and you should find a screw or two remove. there is a bulb under there. just twist counterclockwise and pull it off.
p.s. if you are switching to LED. make sure you get a white LED. i put a blue LED in there and now u can't see P & R since it's filtered out.
Old Aug 23, 2014 | 06:31 PM
stacey88s's Avatar
Funny thing, during my research that video did come up, but I thought it'd be easier to do instead of taking that whole middle console up so I didn't even try it.
But thank you for confirming! Done in 10 minutes.
Mahalo!
Old Aug 23, 2014 | 07:14 PM
xxryu139xx's Avatar
aloha to u too
Old Aug 24, 2014 | 10:43 AM
Steve244's Avatar
Oh yeah, it is lit! I've ignored it for 5 years as it serves no purpose in a darkened interior: you can't tell which gear is selected as there's no tell-tale on the selector. I always just look at the dash board indicator lights to know I've hit the big D.
Old Aug 27, 2014 | 06:35 AM
Li2099's Avatar
Haha just realized too that it's lit.
Old Apr 25, 2016 | 10:53 PM
excelwithme's Avatar
What bulb type for gear shift indicator light?
Just wanted to find out what is the replacement bulb for the Honda Fit 2010 gear shift indicator light.
MonstaMatt
Feb 14, 2026 10:10 PM
Sujeto
Oct 20, 2016 05:52 PM
Getzbie
Dec 31, 2013 01:22 PM
Black01
Jan 8, 2011 10:56 PM
WhiteNoise
Mar 29, 2009 10:26 PM
