driver side transmission mount torn
Old Aug 31, 2014 | 03:02 PM
mxl180's Avatar
Deleted....
Old Sep 1, 2014 | 09:55 AM
Carbuff2's Avatar
The mount only costs $29 - $42 USD at Rock Auto. Appears to be easy to replace once the drivetrain is supported.
More Information for ANCHOR 9250
Old Sep 1, 2014 | 11:22 AM
MTLian's Avatar
Il recently installed that exact mount. I've read only really bad reviews online that the anchor mounts fail very quickly. I just installed it this month so I hope I'm still good. Just know that the mount is cheap but it doesn't have a good reputation.
Old Sep 1, 2014 | 02:44 PM
Carbuff2's Avatar
Rock Auto sells several brands, I have no experience with the Anchor brand personally, just used it as an example 'cause of the nice picture.
Old Sep 1, 2014 | 04:32 PM
Lance's Avatar
Would shoving a white eraser between the gills of the mount give your stiffness as well as back to school savings from Staples? The answer is yes I did so and it was very stiff until they ground to a pulp. But they didnt hurt the rubber in the mount because it is softer yet stiff enough. Cheep fun for a day of hard driving. In my GFs Cobalt I could fit a whole 10mm deep socket passing right through on the lower motor mount. That is some gap these days .
Old Sep 1, 2014 | 07:05 PM
apexanimal's Avatar
that mount is nothing more than a positive stop mount...
it really only serves to stop the motor/trans movement at its limit...
with that said, the first stop to firming up my motor mounts was to fill that one with a crap load of windowweld... and it did help quite a bit...
Old Sep 1, 2014 | 10:55 PM
mxl180's Avatar
I saw your original post. To keep vibration at minimum I was consolidation semi filling it with window weld (leaving some gaps of air).
Old Sep 1, 2014 | 11:27 PM
Jack stands's Avatar
^This.
Mine tore, I was gonna replace it but the rusted bolts broke off in the frame. So, I've driven several thousand miles without it. I'm not dead and the car still runs, so I guess it's fine.
Old Sep 1, 2014 | 11:37 PM
MTLian's Avatar
Originally Posted by Jack stands
^This.
Well, I ended up with a bum input shaft bearing. Might be because of the crooked engine? It's a pretty easy job except the bolts were on suuuuuper tight. I bought the mount for 30$ so no biggie.
ChuckDustin
Apr 12, 2019 12:47 PM
AXE876
Jul 17, 2018 03:22 PM
MTLian
May 2, 2016 12:57 PM
allmotormark
Oct 10, 2014 01:16 PM
lcq4blackstar
Jul 13, 2011 06:04 PM
