Against my better Judgement I cut my springs
Old Oct 6, 2014 | 04:38 PM
radfit's Avatar
Hey guys,
A couple years ago I listened to a car buddy of mine and cut my springs. Now my car rides like shit and is ridiculously low. I'm currently on 17 inch rims and my alignment is not great so I'm running through tires. It looks alright but it's not ideal. I'm thinking of going back to stock, or at least redoing the suspension, and also putting back the stock rims and tires. I don't know a ton about cars and I'm trying to keep the price down low. Should I just get the factory shocks and springs or should I be looking into coil overs? What do you guys think?
Old Oct 6, 2014 | 04:59 PM
Factory stuff will:
-Ride better
-Be cheaper
-Last longer
Cheap coilovers will:
-Suck
Get stock stuff, GET AN ALIGNMENT, call it a day.
Old Oct 7, 2014 | 02:02 PM
domoMKIV's Avatar
What exactly does "keep the price low" mean? $5? $600? $eleventybillion?
Old Oct 7, 2014 | 02:13 PM
Santiad's Avatar
depends on your priorities
Do you want a lower ride that ride a bit better? Get Swift springs....someone here is selling a set for $280 or so....
You might find someone here selling stock springs for about $100
regardless I recommend new shocks since cutting the springs have probably put stress on them they were designed to take. I purchased KYB OEM replacements when I switched to swifts. I like em...
As for the wheels....that is entirely up to you....stock suspension with 17's might touch...not sure.
Budget $400-500 for aftermarket spring setup and $300 for stock.
Old Oct 17, 2014 | 07:05 AM
lee lrd's Avatar
cutting springs really isnt a great choice, not only do you shorten the damper stroke but you send spring rates all over the place...
best bet is get some decent springs and maybe even new shocks if needed incase you have killed yours.
Old Oct 17, 2014 | 12:05 PM
pearl's Avatar
You can run any of the springs you see on this forum with the stock struts for many thousands of miles without any issues.
I have been running S-tech's since 22k and now have 91k on my 08. Rides the exact same way it did when I first put them on.
Old Oct 30, 2014 | 05:44 PM
mahout's Avatar
Originally Posted by radfit
Hey guys,
The best thing for you to do is buy a set of one inch lowering springs; if your current shocks, presumeablyt OEM, are not shot thanks to lowering too much, they are reuseable. If not, new shocks are needed and you might as well get adjustables, like AGX, koni, or Bilsteins. AGX are likely close to OEM shock prices.
Just out of curiosity how much did you cut the springs? More than one coil was too much
Ride and cornering wikll be improved drastically.
Cicatrix
Apr 20, 2011 12:05 AM
dels
Hawaii Community
Mar 31, 2011 05:25 AM
CHERK
Sep 20, 2009 07:02 AM
TOOL
Aug 5, 2008 07:33 PM
Nakamura
18
Nov 8, 2007 04:34 PM
