EGR valve
Old Nov 2, 2014 | 08:16 AM
averona's Avatar
EGR valve
Turns out my hicupping or hesitation came from the EGR valve sticking. Is this an easy repair for an amateur or best to leave it to the pros?
2007 Fit sport.
Old Nov 2, 2014 | 12:40 PM
MTLian's Avatar
2007 Fit sport.
Well I would at least try to clean it. It takes two seconds to undo the little wiring clip and take out the two bolts holding it in. Just spray some brake parts cleaner in there and try to degunk it.
If that doesn't work then you'll have waisted 15 minutes and you'll just have to bite the bullet and buy another
Old Nov 4, 2014 | 09:31 PM
doctor J's Avatar
Please pardon my hostility, but
How did you find out that it is EGR ??
You found this with scanner? your classmate suggested that??
Old Nov 8, 2014 | 02:36 AM
ikutoisahobo's Avatar
Hesitation and hiccuping. Lag in acceleration, misfire, lack of power, ???
Do you have any codes?
And like doctor J said, how are you sure it's the EGR?
Old Nov 12, 2014 | 01:30 PM
doctor J's Avatar
FYI, the "third party" generic scanner may indicate EGR error 99.2% with engine on or off and car is not moving. This error can be disregarded if it changes to 0 if the car is in motion. I found this after driving home with scanner attached.
Steven Hung
16
Feb 17, 2019 03:42 AM
codenamezero
Sep 21, 2016 08:23 AM
Mynodha
Jul 17, 2014 01:25 AM
Lamak
Mar 15, 2009 03:24 AM
Fit of RAGE
Sep 12, 2007 02:47 AM
