Here's My '15 EX
Old Feb 19, 2015 | 09:09 PM
jhn's Avatar
jhn
Here's My '15 EX
My first change was the addition of a receiver hitch for my bike rack:
Changed my springs New Year's Eve:
Changed the horns (no pics of that). I picked up some 25mm spacers for the rear wheels to even the gap:
Early 90's Billet Specialties plate frame from my minitruck; Shaved the Fit emblem w/ dental floss:
Here's how it sits today, but not for long - UPS guy's got some goodies on the way:
Old Feb 21, 2015 | 03:52 PM
jhn's Avatar
jhn
I put my oem tires on some Vision 425's today. 16x7 42et w/ 25mm spacers in the back. I'm just testing it with the spacers, but they're coming off the car. too wide:
Old Feb 25, 2015 | 08:32 PM
jhn's Avatar
jhn
Installed some 10mm spacers in the rear wheels tonight. Perfect spacing with these wheels/car:
Old Feb 27, 2015 | 09:11 AM
jhn's Avatar
jhn
Replaced the factory struts with Koni's last night:
Old Mar 21, 2015 | 02:55 PM
jhn's Avatar
jhn
I added Koni Orange shocks to the rear as well. Much, much better ride quality over OEM:
What next?
Old Mar 21, 2015 | 05:47 PM
Bassguitarist1985's Avatar
How close were the koni rear struts to orm in terms of extended throw? I got monroe maxx air stuts for the rear when towing. A few inches ahy of extended length of the stock struts but shouldnt be an issue.
Old Mar 21, 2015 | 06:28 PM
xxryu139xx's Avatar
damn thats a nice drop for non-coilovers. did the konis add some extra drop?
Old Mar 22, 2015 | 02:34 AM
jhn's Avatar
jhn
They're shorter overall than OEM, but the springs have reduced travel, so as far as total travel compared to OEM I'm not really sure. I think it's a little less overall.
As for the Koni's adding drop-- the rear height is unaffected by them and I was expecting the front to actually be a bit higher because it seems like the perches are higher. It measured out exactly the same ride height as OEM struts and HandR springs.
Old Mar 22, 2015 | 02:38 AM
jhn's Avatar
jhn
More pics of the suspension change here:
https://www.fitfreak.net/forums/3rd-...springs-3.html
Old Mar 22, 2015 | 12:54 PM
Wansel's Avatar
The Car looks great in white. I must admit I really like look of the stock rims a lot more then the black ones. The black stripes are cool in a mini cooper kind of way. They might call unwanted attention from the PD that you might drive, shall we say, enthusiastically. The same reason why I don't/won't own a "Ticket-me-RED" colored car.
Old Mar 22, 2015 | 07:53 PM
jhn's Avatar
jhn
I use my cruise control A LOT. It helps keep my driving in check.
Funny, I built a study in college about the correlation between car color and moving violations. I had a bit of confirmation bias going into it because I thought red cars received more tickets too.
I mean, fire engines are red for a reason, right?
My results were inconclusive.
As for the stripes, I suppose the increased attention could be real, but the way I see it, as long as I keep that cruise control on lock, I should be OK.
That's all it is. (Un)wanted attention.
Old Apr 17, 2015 | 09:48 PM
jhn's Avatar
jhn
I picked up one of these today. Took a bit of work to get it mounted but it is on.
Old Apr 21, 2015 | 07:29 PM
Octopy's Avatar
Man, looks great. I am jealous!
Old Apr 24, 2015 | 11:44 PM
jhn's Avatar
jhn
Thanks! It's a pretty fun little car now.
Old May 29, 2015 | 09:04 PM
Connor Keyser's Avatar
Originally Posted by jhn
Thanks man! It's a pretty fun little car now.
Nice work so far!
What did you have to do in order to install that Bisimoto pipe? And also how does it sound?
Old May 29, 2015 | 09:30 PM
jhn's Avatar
jhn
I had to reshape the mounting hook pretty significantly because it hit my receiver hitch. I'm not sure why, but the hook points forward. The OE muffler points backward. If it was like the OE it wouldn't have been an issue. I bent it in a manner that put the least amount of stress on the weld. Otherwise I would have twisted it. There's only one hook ( OE two) so if it were to break it would fall. You can see it the first pic above how it originally looked. Here's how I bent it:
It sounds great. Imagine how it sounds with the OE axle-back muffler removed and adding a 3" piece of pipe in its place essentially that's what it is. Here's a link to how it sounds:
Old May 29, 2015 | 09:38 PM
jhn's Avatar
jhn
I finally found some center caps that fit and look fairly decent:
I've got my first cosmetic mod in the works. Hopefully it will be done in a week or so. All of the mods I've done so far are performance based. I'm not sure yet how this will look but I'll find out soon enough...
I added all interior LEDs, front type A switchback LEDs turn signals, Silvania Xenons, amber markers, LED plate lights, and a Crosstour hatch lens with on/ off switch. It makes a noticeable improvement. Only a few things left to do. I'm almost done...
Old Jun 8, 2015 | 09:53 PM
jhn's Avatar
jhn
Put a sway bar on it today. Bolted right on! I wasn't sure if it was going to work or not:
Old Jun 9, 2015 | 11:51 AM
TofuShop's Avatar
Is that the GE8 Ultra Racing sway?
Old Jun 9, 2015 | 12:02 PM
jhn's Avatar
jhn
No, it is for the '13+ JDM Honda City. Apparently it shares the same torsion beam with the '15 USDM Fit. Bolted right on. No drilling, no mods. Backed it onto oil change ramps and install. 15 min.
