DIY 2015 honda fit cargo cover
Old Mar 10, 2015 | 10:46 PM
Seaden's Avatar
Today i made my own cargo cover from hardboard and felt.
Old Mar 10, 2015 | 11:03 PM
Seaden's Avatar
Old Mar 10, 2015 | 11:21 PM
xxryu139xx's Avatar
tried to fix ur pic, but flicker doesnt want to play nice
Old Mar 11, 2015 | 12:05 AM
Seaden's Avatar
There i fixed it!!
Old Mar 11, 2015 | 12:36 PM
Oneoldphlaytis's Avatar
What is "hardboard"?
Old Mar 11, 2015 | 01:01 PM
Seaden's Avatar
It is high density fiberboard. I used a 3/16 thick piece that was 2x4 feet. Cost $6-$9 at hardware stores
Old Mar 14, 2015 | 01:22 PM
2fit2kwit's Avatar
it looks good man
Old Apr 3, 2015 | 11:38 AM
Throwin_FitS's Avatar
awesome!! I might do this this weekend
Old Jul 30, 2015 | 11:54 PM
noneterry's Avatar
Does fiber board warp over time? Did you reinforce the cross-span?
I used foam board and it warps like mad. It's $25 down the drain.
Old Jul 31, 2015 | 12:57 AM
Seaden's Avatar
Bows
I used foam board and it warp like mad; $25 into the drain.
It does bow a little but i just flip it every month or so or whenever i noticed or remember. I still use mine and if i made it again i might buy steel to reinforce it but its not a problem and i likely wont need to remake me for many years.
Old Jul 31, 2015 | 07:39 PM
Corsair's Avatar
I have a coupe of cents to add if I may. Im currently building rc airplanes out of foam board, thinner than what you are using I believe. Anyway hot glue is amazing, try cutting a strip or two the length of your cargo cover and about 1 to 1'1/2 and hot glue it to the bottom of the cover edge ways for support, I find it bends when flat but not if you brace it with a piece 90degrees off the flat. Just an idea, I think it looks great though,good work.
Old Aug 20, 2015 | 07:33 AM
2Rismo2's Avatar
I made a DIY cargo cover and used cheap curtain rods as support. This is what I'm talking about:
Looks like this underneath. They are positioned so they sit on the "lip" of the shelf supports. It's quite strong, yet still very lightweight. This thread actually gave me the idea to try it on my own. I found the foam board did bend over time, so I added the curtain rods and haven't had a problem since:
Finished product:
Spent less than $30 versus buying the Honda spec one
Old Sep 6, 2015 | 07:16 AM
noneterry's Avatar
Originally Posted by 2Rismo2
I made a DIY cargo cover and used cheap curtain rods as support..........
That looks awesome. Where did you guys manage to find that large piece of felt? At Michael's?
Also, what do you use to stick the felt securely onto the board? Will hot glue gun work?
Old Sep 10, 2015 | 07:25 AM
2Rismo2's Avatar
Sorry, didn't see this post earlier. I bought the felt at hobby lobby, but I imagine any craft store like Michaels would have it. Even Walmart has a fabrics section. I used a spray adhesive. I put multiple coats and let it dry tacky for a few minutes. Then press it down firmly and put something heavy on it for a while. If you use hot glue, it may show the thicker lines of glue.
NotBlake
45
Jun 26, 2021 08:28 PM
amyvegan
Jun 25, 2015 01:01 AM
llachef
May 4, 2015 03:14 PM
Honda lover
Sep 12, 2014 10:12 PM
