is there any problem of lowering?
Old Sep 27, 2006 | 02:52 PM
Keep Fit's Avatar
right now I have HFP rims with 205/45R16 tires
I am planing to install H&R lowering spring, will there be any problem?
Old Sep 27, 2006 | 03:34 PM
Wave's Avatar
speedbumps grinding the underside - I have a Fujitsubo Power Getter cat back and Skunk2 Springs and sometimes the resonator scrapes.
the frontlip of a Sport will scrape depending on the approach angle
wondering how long the stock shocks and struts will hold out with my daily commute from Long Island to NYC.
Old Sep 27, 2006 | 11:47 PM
MINI-Fit's Avatar
Whenever lowering your suspension there is risk for rubbing.
Ask your vendor if the H&R springs will rub with your HFP rims (find out the dimensions and offset of the wheel to report to them).
Look at the current clearance you have now using stock springs. Figure out how much drop you will get and imagine how low you will go. Does it look close? If so then with a load of passengers you might get some rubbing. The 205mm tires are somewhat wide.
You can also ask Jim@tirerack.com about fitment in this situation.
Old Sep 30, 2006 | 03:47 PM
jim@tirerack's Avatar
Former Vendor
As long as the wheel and tire tuck into the wheel well now you should be fine. The ground clearance is always a problem but you just have to drive a little more carefully. Like WAVE stated speed bumps and curbs are the main thing.
Old Dec 9, 2006 | 06:04 PM
arsonall's Avatar
as with any change in suspension, you'll also want to have an alignment shop take a look at it. i made the mistake of thinking my car looked aligned, only to find out that 6 months later, i had no more rubber on the edges of my tires.
Old Dec 10, 2006 | 08:33 AM
CarDemon's Avatar
Senior Member
H&R's...good choice my friend.
Old Dec 10, 2006 | 12:58 PM
etong's Avatar
i think that depends on how big the drop is. if you do too low, the front will bottom out quite a lot.
Osigina12
Nov 3, 2023 08:30 AM
tk9985
3rd Generation GK Specific Suspension & Brakes Sub-Forum
13
Jan 22, 2021 02:27 AM
pandapandared
Jul 28, 2012 12:30 PM
Speedlimitz
Jul 12, 2012 02:32 AM
Kolbotn
Apr 15, 2008 04:50 PM
