Front/Rear Speakers Upgrade for a GE8
Old Mar 29, 2015 | 09:27 PM
luismycorreo's Avatar
Hello Fitfreakers
Please use this post to share your knowlege in speaker upgrades for an HONDA FIT GE8
I was wondering if someone has try the Pioneer TS-A1685R??? is there enough housing in the front & rear doors??
I found these adapters on Aliexpress (compared to OEM Speakers seems to be same size)
Honda Speaker Mount Plates Adapters
Luis
Honda Fit Sport 2013 - Vortex Blue Pearl
Old Apr 9, 2015 | 12:35 AM
Desmond Lamar MacRae's Avatar
Originally Posted by luismycorreo
Hello Fitfreakers
Luis
Any brand is carry a brand, there's your answer. Thant said, you might as well keep the stock speakers.
Old May 12, 2015 | 06:14 PM
Finally I decided to install the Pioneer TS-A1685R in my Front Doors, i can confirm there is enough housing space to install those speakers and the adapters from Aliexpress works very good.
Here you're some pictures
Front Door - Gathers Speakers GS-5060XL - Honda Access P/N 08a38-0h0-550 (now in my Rear Doors)
Honda-Acura Speaker Mount Plates Adapters
Install first the Speaker Mount using the factory screw, then use the Metra 72-7800 Honda and Acura Speaker Adapter Harness Connector (available on AMAZON or EBAY)
Finally use some screws to fix the speakers (I use screws 6x5/8 and some fixing rings)
à
I found these other speakers adapters
Scosche SAHR6 2006-Up Honda Ridgeline Speaker Adapter Scosche SAHR6 2006-Up Honda Ridgeline Speaker Adapter
Hope this information helps you...
Luis
Old May 13, 2015 | 02:31 PM
Jmsutton's Avatar
I went with Polk audio DB 165s shallow mount. I'm still installing right now have the doors pulled off and my Rockford amp all set up just have to finish dropping them in. I'll post some pictures when I'm done.
Old May 14, 2015 | 08:10 AM
Originally Posted by Jmsutton
I went with Polk audio DB 165s shallow mount. I'm still installing right.........I'll post some pictures when I'm done.
Excellent Jmsutton, waiting for your pics
I'm thinking to replace my rear speakers by ALPINE SPR-60 6.5" 2-WAY COAXIAL SPEAKERS
Tweeters are OK for now, I don't need more high tones.
If someone has information about Foam Speaker Buffles, seems to be a good product to protect the speakers from water leaks but I don't know if its will affect the speakers performance.
Luis
Old Jan 12, 2017 | 04:43 AM
zeniitti's Avatar
Do you think that these adapter rings would be a direct fit to 2012 Jazz/Fit? As your aliexpress link is not working anymore
For Honda Civic 2001-06 Speaker Adaptor Rings 6.5"/6.75" with Wire Cable Adaptor | eBay
Old Jan 25, 2017 | 03:52 AM
zeniitti's Avatar
Any possible help with the rings?
Old Feb 3, 2017 | 01:11 AM
zeniitti's Avatar
I ordered those rings.
Old Apr 19, 2017 | 02:02 AM
zeniitti's Avatar
This was a perfetct fit
carolina_cruising
Dec 24, 2013 11:21 AM
polokid69
Jan 15, 2013 04:52 PM
Java^FiT
18
Jul 14, 2011 09:59 AM
polokid69
Nov 14, 2009 01:42 PM
Ian
Jul 19, 2005 11:30 AM
