hps short ram question.
Old Apr 4, 2015 | 02:38 PM
wzlfit's Avatar
I recently installed the hps short ram & so far I'm quite happy with it. My question is about driving in reverse. When backing into a spot or my driveway it sounds like the car sits on a giant whoopee cushion & you can feel the vibration as it happens. Does this happen for anyone else? Is it normal or did I install wrong? I'm ok with it as long as it's supposed to sound like that.
Old Apr 5, 2015 | 12:04 AM
xxryu139xx's Avatar
ur saying ur car makes a farting noise???? how about trying to record the sound =p
Old Apr 5, 2015 | 11:51 AM
Myxalplyx's Avatar
Maybe all the extra air being let in makes it pass more gas.
**In for a video**
Old Apr 5, 2015 | 12:32 PM
wzlfit's Avatar
I will try for a vid but my phone has bad sound. And yes, it totally sounds like a fart.
Old Apr 5, 2015 | 01:16 PM
wzlfit's Avatar
I just tried using my phone & get wind noise. Backed into the drive like 10 times, neighbors must think I'm nuts. It doesn't do it as readily when I try, maybe it's my footwork. I got a friend with a good camera I will try that.
Old Apr 8, 2015 | 01:18 PM
wzlfit's Avatar
http://vid1266.photobucket.com/album...407_104311.mp4
The fart sound comes after i straighten out backing in at the end of the vid.
Old Apr 8, 2015 | 01:27 PM
yovtecjustkickedin's Avatar
Have the HPS Short Ram installed on my 2010 Honda Fit Sport Manual and more than 5k miles on it (& Love it). Don't have this issue. Check install - you might back up with the hood up and someone watching the intake. My guess is it is rattling against something. Perhaps there is a motor mount issue allowing your engine to move around more so than it should?
Old Apr 8, 2015 | 02:48 PM
Myxalplyx's Avatar
There's definitely something vibrating. I find it more than just a coincidence that the camera shook at the exact time the sound took place. Can't imagine what it could be though (Intake, exhaust) ??? Perhaps something that vibrates right at the rpm range. Yes...I can understand your frustration. Thanks for the video! Perhaps I can find this somewhere else and give some suggestions. I'll look!
Also, I notice it happened right while you accelerated from a stop, while going backwards, going uphill. Does it usually do it then only?
Old Apr 8, 2015 | 02:51 PM
Myxalplyx's Avatar
According to this thread --> Slight vibration when backing up? - MBWorld.org Forums
it was the transmission mounts.
Old Apr 8, 2015 | 03:11 PM
wzlfit's Avatar
It sounds like it is coming from about where the intake would be (if you're in car) and you can feel the vibration in the steering wheel and pedals. the phone mount is crap and going over bumps like curb it rattles too. It seems to happen at a lower rpm just starting to go in reverse. I don't know the name of the part but there is a flapper just past the intake, it sounds like it flutters. I would think a tranny mount would feel more in the seat and frame. As far as elevation there is a dip where my curb is but my drive is quite flat and it sometimes happens when I start my turn into the drive.
thanks to all for helping me think through this
Old Apr 8, 2015 | 03:13 PM
wzlfit's Avatar
Also the sound is deeper in real life. You only hear mids up in the video.
Old Apr 8, 2015 | 03:28 PM
wzlfit's Avatar
the link goes to a blank page for me
Old Apr 8, 2015 | 05:38 PM
Myxalplyx's Avatar
That's strange! Works fine for me. Even still, the transmission mount is what they found.
Here...I'll try a different way. It will be the first link that pops up.
http://lmgtfy.com/?q=amg+vibration+when+backing+up
Old Apr 9, 2015 | 01:52 PM
wzlfit's Avatar
Let me google that for you
Worked that time. Seems similar to my issue, I just dont see how it would be bad on a 2 yr old car. I actually was planning on going in for an alignment next week, I'll let a professional check it out
Old May 2, 2015 | 06:20 PM
wzlfit's Avatar
Took my car in for an alignment and asked them to check the motor/ tranny mounts but all checked out. Maybe it's because i have the trans mount in my head but the more I listen and feel I wonder if my car guy is wrong. Maybe it's normal but I feel like the car waits then catches when i down shift and when I accelerate after shifting i feel a slight bump just as I let out the clutch. I'm pretty sure I'm not dumping the clutch, I've been driving MT for almost 21 years. I plan to take it to a dealership for a second opinion but any suggestions here are welcome and appreciated. I also plan to update till I find a solution so others can possibly beneFIT.
Old May 11, 2015 | 03:18 PM
wzlfit's Avatar
I found the cause! The fart noise was the filter hitting the plastic part between the intake and the battery. Thumb & 1st digit were the only tools needed to fix it. This has gotten me thinking about motor/tranny mounts. I'm a down shifter and would like to find more durable mounts and maybe a torque damper. This car has always felt touchy when letting off on the accelerator in 1st/2nd. I feel like the damper might help with that.
korgster
Nov 18, 2016 08:05 AM
toomuchjoy
Jun 10, 2012 09:31 AM
MINI-Fit
Hawaii Community
Dec 21, 2009 04:01 PM
Rod2Rice
Oct 19, 2008 04:33 PM
kgustaf
Feb 2, 2007 01:39 AM
