(Not) typical question about disconnect DRL's
Old May 28, 2015 | 07:42 PM
hogwylde's Avatar
I pulled the fuse on the DRL's to see if I would like it and besides them being off, I can see no advantage or what there's to like or dislike about it. I would have liked it it the dash wasn't lit 24/7 but it still is. The ONLY advantage I can see is if I am TOTALLY distracted, the DRL's won't make me think my headlights are on at night when they aren't.
So why do you guys disconnect yours?
Old May 28, 2015 | 08:01 PM
xxryu139xx's Avatar
odd how your DRL light is on. mine isn't.
Old May 28, 2015 | 08:18 PM
hogwylde's Avatar
My DRL's are out.
I was saying that it would have been nice if the fuse also turned my dash off (except when headlights are on).
I'm just looking to see what the "advantage" is of having no DRL's (if any).
Old May 28, 2015 | 09:00 PM
xxryu139xx's Avatar
only advantage is to preserve your HID bulbs.
Old May 29, 2015 | 07:37 AM
GoBucky's Avatar
I have mine disabled to reduce wear & tear on the headlights and to reduce the load (albeit minor) on the engine and battery.
Old May 29, 2015 | 08:08 AM
Uncle Gary's Avatar
Being that the DRLs use the high beam at reduced voltage, I can't imagine there is much "wear and tear" to consider. Incandescent lamps run at reduced voltage last exponentially longer. I have only anecdotal evidence to offer, but every time I've burned out an H4 lamp in my Fit, it's ALWAYS the low beam that fails. If the DRLs were wearing out the bulbs I'd expect the high beam filament to go first.
Old May 29, 2015 | 08:11 AM
GoBucky's Avatar
Yes, but the fact that your DRLs are on 100% of the time that your ignition is on, will create wear on the filaments.
Old May 29, 2015 | 08:19 AM
Uncle Gary's Avatar
Theoretically, yes, but as a practical matter, it's so minimal due to the reduced voltage that it's not worth it for me to worry about it.
Old May 31, 2015 | 01:31 AM
Codger01's Avatar
I pulled the fuse because I don't like the whole idea behind DRL's. No advantage.
grradams
Aug 24, 2018 05:18 PM
Irish
Jan 27, 2016 06:36 PM
andre181
30
Jun 1, 2015 12:43 AM
gd3vbp
Jun 24, 2009 04:58 PM
VaJim
Feb 26, 2009 02:39 PM
