Wider tires ?
Old Jun 23, 2015 | 04:52 PM
KennyisFez's Avatar
Wider tires ?
Hey there, I have a GD fit with stock wheels. Been wanting to make the plunge and get 15" rims. I was curious what's the widest size tire you can get away with ?
Old Jun 23, 2015 | 08:39 PM
GolNat's Avatar
If it's 5.5" wide you could go 205, 6" a 215. You want to keep rolling diameter the same so you want a size that will closely match that.
Here is a good calculator:
https://www.tacomaworld.com/tirecalc
The tire spec will specify a rim width range.
Old Jun 23, 2015 | 10:22 PM
Hootie's Avatar
Depends on your car's suspension and alignment setup along with wheel/tire specs. 205/50R15s will work FINE on stock suspension even with a factory wheel. Just need to research a bit beforehand and be mindful of the wheel's width and offset.
General rule of thumb is with stock (not sagging) suspension you can run a 205 on a 7 inch wide wheel with an offset as low as +42mm. Lowered, with same wheel/tire size you can safely run a +45mm offset.
I personally daily a square 205/50R15 on 15x7 ET+42 wheels. For autocross, I run a reverse stagger 225/45R15 on 15x9 ET+35mm and 205/50R15 on 15x7 ET+35mm. No tire rub AT ALL.
Old Jun 23, 2015 | 11:10 PM
KennyisFez's Avatar
Cool guys thanks for the help ! Time to find some rims I like then.
Previc93
Mar 6, 2013 01:44 AM
kevinkidstar138
Oct 20, 2011 09:44 PM
Halcyon
Nov 25, 2010 07:15 PM
khanhdom
Sep 27, 2008 07:06 PM
base model 5MT
Mar 29, 2008 02:04 PM
