Brand New Owner-AM Radio Issue
Old Sep 12, 2015 | 10:54 PM
textrex's Avatar
Hi all,
I'm so glad I stumbled on this forum, from reading around a bit you all seem super helpful!
As it says in the title I'm a brand new owner of a 2013 Honda Fit Sport. I'm loving the car in the short time I've had with it, except that the AM radio will not pick up anything but static. There are no weak signals fighting to come through, just plain static.
It might be lame but I basically exclusively listen to AM so this is a bit of an issue for me.
Thank you all for reading.
Old Sep 13, 2015 | 12:35 PM
ezone's Avatar
Does the radio work good on FM?
Did someone steal the antenna off of the roof?
Old Sep 13, 2015 | 12:50 PM
textrex's Avatar
Antenna is firmly in place, and the radio works beautifully on FM channels.
Thanks for the reply!
Old Sep 13, 2015 | 01:09 PM
ezone's Avatar
AM and FM use the same antenna so I'd wild guess a radio problem, but there is also an antenna amplifier that could be an issue....
I might connect a test antenna in the back of the radio or into the antenna wire harness and see if it makes any difference in reception just to make sure its not in the cars antenna stuff.... before spending money on a radio fix
There's an antenna lead connector in the right front kick panel area, and there's another antenna connector in the right rear upper pillar trim cover
Old Sep 13, 2015 | 09:17 PM
textrex's Avatar
So after much frustration I found an AM station that is coming through very weakly, so it seems to be a reception issue.
Where can I go from here?
Old Sep 13, 2015 | 09:36 PM
ezone's Avatar
Ok I made a reply but there's a link in it so a moderator has to approve it.
Old Sep 13, 2015 | 09:38 PM
textrex's Avatar
Thank you so much for taking the time to help out!
Old Sep 13, 2015 | 09:43 PM
ezone's Avatar
It was basically rehashing post #4 but with a hopefully helpful picture of an antenna connector. Check the connectors, unplug and replug them, and check for 12v on the power lead at the rearmost connector.
Old Sep 23, 2015 | 03:51 AM
gallent92's Avatar
Sounds the radio is ok to me, just the antenna connection on the AM that come to loose since you able to at least get a weak reception.
kbonus
Nov 10, 2014 04:52 PM
SilverEX15
Aug 2, 2014 06:38 PM
granburysprint
Oct 5, 2009 04:47 PM
gar1013
Jan 22, 2009 09:44 PM
bigtoepfer
May 22, 2008 11:10 AM
