Transmission differences, help a newbie out.
Old Oct 27, 2015 | 10:38 PM
Newbiefitfreak's Avatar
If a CVT is continuously variable transmission and that means it's always picking the best gear ratio and DCT is dual clutch transmission which is basically for even faster smoother shifting than manual transmissions then what is its combination benefits.
If an automatic car had DCVVT (dual continuous variable valve timing) transmission is it better for paddles or is the manual better? Will the paddles shift faster and will the engine rev more efficiently?
Furthermore if you know, does modifying it require more connections with electronics?
If anyone can help me out with finding answers that would be great!
Old Oct 28, 2015 | 06:09 PM
DrewE's Avatar
I think DCVVT refers to the engine, not the transmission—changing the timing on the intake and exhaust valves.
Unless you're manually shifting really quickly and maniacally, a decent automatic should probably be able to actually change into a new gear range more quickly than a manual. There is often somewhat of a delay between you asking the automatic to shift and it actually doing the shift, though.
As to which one gives better gas mileage, that depends on a lot of variables. A manual or a DCT transmission should have the lowest parasitic power losses, I think, while a CVT is able to keep the engine RPM at the most efficient spot for the power required (though not many do this too precisely). On the Fit, things are further complicated by the manuals having a rather different overall top gear ratio than the automatic or CVT transmissions. Much of this pales in comparison to much more basic things that affect mileage like how fast you drive and how frequently you need to stop and how long your trips are.
Old Oct 29, 2015 | 10:24 PM
It's the transmission of the car for sure. I just don't understand what the combination of a dual clutch and a CVT together mean for the engine and it's auto transmission. Does this allow as fast acceleration as a manual because of dual clutch and "perfect" rev points?
Old Oct 30, 2015 | 02:27 AM
ezone's Avatar
You seem to be attempting to blend the acronyms DCT and CVT, those are two vastly different transmission technologies and they are not combined together by any auto manufacturer on the planet at this time.
DCVVT stands for Dual Continuously Variable Valve Timing. (Google it if you need to.)
It has nothing to do with the transmission.
The acronym is not used by Honda.
HTH
Old Nov 1, 2015 | 06:34 PM
this thread is funny..
Old Nov 1, 2015 | 07:19 PM
Fit Charlie's Avatar
Well, mine's got a VVTec with an MDS, a SCSI ECU and TCM and a minimum of eight other TLAs.
CJfit15
Aug 19, 2015 03:45 PM
liquid crystal
Jun 3, 2009 09:55 PM
CTStalker
Oct 7, 2008 07:27 AM
pcs0snq
Mar 20, 2008 12:48 PM
FreakinSyco
Nov 19, 2007 02:41 AM
