Ignition switch will not turn
Old Dec 8, 2015 | 04:27 PM
Fitgirl99's Avatar
I have a 2009 manual transmission. . Yesterday the key had some resistance going into the ignition switch and when inserted fully would not turn. I sprayed with WD-40 and Graphite. This made the key easier to insert but still did not allow for the switch to turn. I turned the steering wheel between the two stops and tried for 2 hours to get it to turn. I tried my usual key and my unused spare, with the same results. I finally got it to turn once and drove it to my mechanic. He called this morning and said I would have to take it to a dealer. The ignition switch is defective. He got it to turn once but that was it. Might be $$$.
I did a search and saw a few people with this problem but not many. How common is a defective ignition switch for 09s, and do I have any leverage with the dealer. Warranty is expired.
Thanks for your feedback
Old Dec 9, 2015 | 03:50 PM
Macswfc's Avatar
Had a similar issue, had to get the ignition cylinder fixed (dealer called in a locksmith) and I got a new key made as the old one was worn and probably caused the issue in the first place.
Old Dec 10, 2015 | 08:55 PM
geopat's Avatar
Had something similar happen to my gd last year. The dealer wanted around $500 for a replacement switch assembly. They wouldn't sell just the tumbler and column lock which is all I needed. Ended up buying a column from a wreaker for $100 swapped in my tumblers so I retained my stock key and bolted all of my electronics to the new part.
Old Dec 11, 2015 | 04:10 PM
Txfitish's Avatar
Has happen to me before anyone have any clues?
Fweemn
May 17, 2023 10:43 PM
soccerdude
Sep 17, 2014 10:56 PM
gcisko
May 13, 2011 06:13 PM
CuTeBoi
Jul 10, 2007 07:08 PM
Anastasio
Jul 3, 2005 11:20 PM
