Tick or Knock even with valve adjustment?
Old Feb 28, 2016 | 10:56 AM
allTRACway's Avatar
I adjusted my valves because I had a mad tick all the time but around 3k the engine sounds like it's got a rod knock when under 1/4-1/2 throttle acceleration but makes no nois under full acceleration. Did the valve lash and all the ticking got quieter, or so I thought, the normal tick is gone but the 3k tick is is back after 10 miles or so. My plan is to open it back up in about 1k miles and readjust the valves. Any ideas? I wasn't able to find any posts about my specific issue. Is this normal?
Old Feb 28, 2016 | 02:04 PM
Santiad's Avatar
sewing machine
Our engines are normally noisy, like a sewing machine....also I've noticed and a few others with AT, that the engine hates mild acceleration, anything lower that 2.5k is usually met with a weird noise and sensation....
I have adjusted my valves 3 times during my ownership and with 143k on it, will need another soon....
be careful to adjust within spec though, anything outside of that will hurt.
Old Mar 5, 2016 | 12:34 PM
Mister Coffee's Avatar
What year is your car, Santiad?
Thanks.
Old Mar 5, 2016 | 01:08 PM
Codger01's Avatar
I've been told the tick is the sound of the fuel injectors firing.
Old Mar 6, 2016 | 12:49 AM
Santiad's Avatar
09
Thanks.
It's a 2009
Old Mar 6, 2016 | 11:52 PM
bargainguy's Avatar
Can you record the tick at 3K so we can hear it for ourselves?
Outside of that, wild guess: Bad motor mount. Sometimes more noticeable at low rpm than WOT.
Old Mar 7, 2016 | 02:52 PM
It's a 2009
Mine's a '13. And it's the noisiest engine I've ever owned. Sounds like valve train noise. Could be injector noise. I've been told by the dealer (more than once) that it "sounds normal" to them. I opened a case file with Honda just to get on record. They said if I'm not satisfied I should try a different dealer. The next dealer I went to wanted $150 up front just to listen to the engine. I told them to take a hike.
For now, I have decoded to just drive the thing into the ground and buy something else when I get the money.
Old Mar 9, 2016 | 08:11 PM
Osubeaver's Avatar
I always felt my 2010 was loud and so harsh sounding near redline. I've come to accept that this is just a noisy ticking motor.
Old Mar 10, 2016 | 02:14 PM
It's a great little car, with good torque and a sweet gearbox, and just fun as h*ll to drive, but it is noisy. Worryingly so.
Old Mar 10, 2016 | 05:39 PM
dwtaylorpdx's Avatar
All the direct injected engines are getting people complaining about the noise, not just honda..
Old Mar 10, 2016 | 11:39 PM
But my '13 isn't injected. My '08 wasn't either.
Old Mar 11, 2016 | 04:06 PM
I knew the 08 wasnt,,, thought the gen 3 and up were.. My bad..
fujisawa
Oct 22, 2018 11:27 AM
sunnyday
May 27, 2017 09:18 AM
g fit
May 12, 2014 07:06 PM
der Mond
Jul 3, 2011 09:29 AM
ricohman
May 22, 2011 09:34 PM
