My hatch door is stuck, can someone please help me open it?
Old May 7, 2016 | 12:17 PM
Vash's Avatar
Idk whats wrong with it.. i have to use it really bad today to take some stuff to a junk yard, and when tried to open the hatch its like the handle is already stuck on the "open" position and Idk what to do make it unstuck.
Old May 7, 2016 | 12:54 PM
it's corroded. just take a peek up the handle area. happened to my 09 GE when i had it too the last yr of ownership. i sprayed some WD40 in there to clean, followed by some white lithium grease spray.
Old May 7, 2016 | 10:23 PM
Odie's Avatar
You'll need a strong flashlight and protective glasses ( goggles ) . Spray a white lithium grease ( stated above ) that thickens in time . Will want to use soft paper towels or rags to clean off excess that runs out . It will be necessary to lube every month or 2 . It depletes from rain , etc..
Old May 8, 2016 | 01:18 PM
fujisawa's Avatar
There is a plastic cover in side where you can access the mechanism.
Old Aug 9, 2016 | 01:26 PM
dll932's Avatar
A shot of WD on the pivots (outside) did the trick instantly.
BlueBoogers
Jun 15, 2022 03:02 PM
shawnshank
Nov 29, 2017 04:36 AM
martyirish
Mar 27, 2013 01:39 AM
martyirish
Mar 25, 2013 07:55 PM
90crxfreak
Jan 12, 2010 11:54 AM
