DIY Diagnostics OBDII
Old May 14, 2016 | 12:27 PM
HermTDI's Avatar
I know that there are 100's of generic DTC readers on the market.
Being an owner "enthusiast" I prefer to go a little deeper than the ENG Check Light. Having a VW I bought VCDS which is a diagnostic application that gives the owner the nearly same features in the VW dealership shop and I liked having that level of data access.
So I did a lot of reading at what is available for my 2015 Fit.
I pulled the trigger on this:
New 2016 Honda HDS 3 017 012 ECU Rewrite Diagnostic Software for Acura Honda | eBay
I need a dongle to connect the laptop to the OBDII port.
I decided upon the Xhorse MVCI
I'll update when this arrives
Old May 14, 2016 | 09:33 PM
bach's Avatar
Pardon my ignorance but will you be using this to rewrite code or use it for advanced monitoring?
Old May 15, 2016 | 12:30 PM
HermTDI's Avatar
Mainly for more detailed monitoring.
The generic code readers only read the engine control unit(ECU).
There are many controllers on new cars ie ABS, automatic trans, door locks, radio, ESP, seat belts & air bags ect. ... ect. Accessing these controllers requires a more robust diagnostic package.
As for re-flashing code I prefer MPPS.
Old May 15, 2016 | 09:25 PM
bach's Avatar
A little while after I got my '02 GTI and I went to a meetup and a guy there misunderstood something I said and turned off the seat belt alarm with a VAG-COM. I was blown away that you could change something like that. I guess I didn't realize there was something similar for the Fit. I got an Ultra Gauge Blue last year, it does pretty deep dive but like you said it's all off the ECU.
Old May 15, 2016 | 11:07 PM
HermTDI's Avatar
Yes, if you drive a VW, Vag-Com is the tool to own.
When I get this Honda software up & running I'll let you know.
There are a few things I want to turn off auto-door locks, and that seat belt alarm has to go post-haste.
Old Jun 8, 2016 | 09:48 PM
bach's Avatar
Hey can this setup be used to program a key fob?
Old Jun 9, 2016 | 08:38 AM
ToddF's Avatar
If it can do keys and TPMS sensors, I may be buying it, too. I've got both a 2013 FIT (with wheel mounted TPMS) and a 2016 FIT (RPM based TPMS). Both have keys that require expensive reprogramming if lost and replaced. It infuriates me to have to pay a dealer programming fees for something I could do myself if I had the right software.
Youaretyping
Aug 6, 2024 01:19 PM
Edison Carasio
May 25, 2023 06:25 PM
FITDragon
Nov 11, 2021 09:08 PM
Wlakey32
Jan 14, 2021 07:54 PM
Kevinbautista9
Feb 27, 2016 03:38 PM
