jacking up rear of car with tow hitch installed
Old Jul 6, 2016 | 10:18 PM
Greendog's Avatar
Could those with tow hitches installed (Curt/Hidden Hitch/etc) please point me in the right direction: what jack points do you use to raise the rear of your GK? Is there way to avoid doing one side at a time?
With the car's built-in tow hook covered up, the preferred jack point is lost... I think... I'm hoping for a single jack point for the rear.
Old Jul 7, 2016 | 03:10 PM
Bassguitarist1985's Avatar
no single point, lift points are in front of the rear tires
Old Jul 7, 2016 | 05:45 PM
Greendog's Avatar
Was afraid of that, but thank you. I do have another question if one lifts the car from in front of the rear tires: where do you put the jack stand if that jack point is used up by the floor jack?
The only other way I could figure out is to use the front jack point (i.e. behind the front tire) with the floor jack and lift the car high enough to get the jack stand under the rear jack point (i.e. in front of the rear tire).
Old Jul 7, 2016 | 09:25 PM
No lift points near fromt bumper. Lift point back of front tires and front of rear tires. Potential jack point at center cross member for front clip but its too deep under the car its a danger.
Old Jul 8, 2016 | 09:49 AM
jhn's Avatar
jhn
I jack mine at the K member in front, then place the jack stand at the pinch seam. I jack up the back under the receiver hitch and put the jack stands at the pinch seams.
Old Jul 8, 2016 | 09:52 AM
jhn's Avatar
jhn
Old Jul 9, 2016 | 06:26 AM
Carbuff2's Avatar
Just to make you guys with the newer Fits jealous,
I can jack our GD Fit with both F&R tires off the ground from the front jacking point (the one behind the FRONT wheels).
But to get only both rears off the ground, I DO use two jacks on the points ahead of the rear wheels. It's a heckuva lot more stable that way, anyhoo.
Old Jul 9, 2016 | 07:06 AM
jhn's Avatar
jhn
I can jack either end of my car (GK) from one point. One single point under the K member and one point under the receiver (tow loop).
neteng101
Jul 18, 2016 08:37 PM
sharkytm
Jul 5, 2012 03:41 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
ericman20
Mar 29, 2008 08:09 AM
Illusive
Sep 9, 2007 07:16 PM
