Another engine splashguard thread
Old Jul 16, 2016 | 11:29 PM
ncoflin's Avatar
Angry Another engine splashguard thread
Okay so I know from snooping around on these forums previously the engine splashguard is a huge design flaw/issue with the 3rd generation Fits. About a year and a half ago my splashguard fell off to the point it was dragging the street to which I had fixed at the dealer. Now again I look under my car and it is hanging low where several clips have yet again clearly come off. Since the 3rd Generation has been around for a while now and there hasn't been a recall on this issue, has there been a consensus on the best way to handle this issue?
I don't feel as in I drive the car very rough nor do I live in a particularly cold climate where road ice and such is a big issue. I get my oil changed at the Honda dealer, so they remove and put it back on. I feel like it is only a matter of time before it completely falls off again or to the point where it is dragging the road as I drive, so it is total dealbreaker to just remove it entirely? This isn't an issue I feel as if I should have to deal with on a consistent basis but since I have to anyways apparently what is my best recourse?
Old Jul 17, 2016 | 08:21 AM
ezone's Avatar
Making contact with a parking block can easily damage the shield. Seems to happen a lot since the cars don't have a lot of ground clearance.
It's damaged and dragging or hanging, I'd remove it. Watch out for tall objects.
It helps the aerodynamics under the car, so mileage might drop just a hair.
Old Jul 17, 2016 | 08:56 AM
stembridge's Avatar
This issue isn't unique to the Fit, unfortunately. My '00 New Beetle had the same setup and same problem. I ended up replacing with an aluminum "Panzer Plate," that added better hard mounting points, too.
Nothing similar is offered for the Fit, though.
es
Old Jul 17, 2016 | 03:19 PM
ncoflin's Avatar
I've heard some people say that the splashguard actually protects the bottom of the car from moisture and stuff but online it's hard to tell what is true and what is just opinion based on non-facts. I would love to keep the splashguard on but if it repeatedly falls off like that then to me it isn't worth it. I don't want to risk being stranded on the side of the road because one of those plastic clips breaks and it is dragging the street.
Old Jul 17, 2016 | 05:22 PM
Alco RS-1's Avatar
Sorry to be off generation, but does anyone know if the 2nd Gen GE8 (North American) has an engine splashguard? I was under my "new" used 2013 this afternoon and don't see one, but do see where one might have been.
Old Jul 17, 2016 | 06:27 PM
BenQuick's Avatar
Originally Posted by Alco RS-1
Sorry to be off generation, but does anyone know if the 2nd Gen GE8 (North American) have an engine splashguard? I was under my "new" used 2013 this afternoon and don't see one, but do see where one might have been.
The first drawing (2016) shows a splash shield. The second drawing (2013) doesn't show one. So I'd say the answer is no.
Old Jul 17, 2016 | 07:06 PM
ezone's Avatar
I thought a few people have installed the splash shield from the CR-Z onto the 2nd gen Fit.
Old Jul 17, 2016 | 07:13 PM
Alco RS-1's Avatar
Thanks Ben, seems like a good conclusion.
Old Jul 18, 2016 | 07:41 AM
Uncle Gary's Avatar
My '09 looked like there were mounting points where a shield COULD have been, but there was none there, so I'd say "no", at least in the NA market.
Old Jul 18, 2016 | 07:42 AM
Uncle Gary's Avatar
I don't understand why anyone would do this. The car is so SHORT that there is no need to pull up until you hit the "car stop" except for carelessness.
Old Jul 18, 2016 | 07:52 AM
not sure why u guys are having issues. ive done the oil change on the GK a few months back, yes the hardware honda uses do suck, but no issue with it undoing itself. did ur dealer do an oil change before the shroud came off?
ive had instances where the screws came undone after i let my dealer do a complimentary oil change on one of my other cars i owned in the past. never again i let dealers touch my cars unless recall repair i cant do on my own.
Old Jul 18, 2016 | 07:15 PM
dwtaylorpdx's Avatar
The splash guard on my GD looks like the big piece in the upper left corner of the lower pic.
So there is one in the pic its just way different than the 2016...
Old Jul 19, 2016 | 02:22 PM
salamlaith's Avatar
don't hit it on bumps, not problem.
the car is low, but that's how it is.
Old Jul 21, 2016 | 12:43 AM
So it is's Avatar
I'd also like to know the diameter of the pins used so I can shop around online for alternatives without paying the pricing of the dealer's OEM replacements with shipping. I'm sure there's a similar style push/screw pin that can be bought in bulk, but I want to make sure the size is correct. Anyone order alternative replacements that they know will work?
Old Jul 21, 2016 | 08:49 AM
oiric2006@gmail.com's Avatar
On the right side of my splash guard all the screws and Pushpin are gone. Zip tied them all and holding up well. I don't wanna go back to the dealer for it. Waste of time. It's a design flaw.
Old Jul 21, 2016 | 02:33 PM
ezone's Avatar
Pushpins can be various sizes and lengths and styles. The larger ones are usually 10mm diameter, others may be 8mm. Measure the holes you have (innermost holes) and see.
The splash panels don't always use pushpins either, many use screws and speednuts.
Or a combination of any of these.
Old Jul 21, 2016 | 07:17 PM
Alco RS-1's Avatar
For 10mm holes, try Dorman 963-500 at AutoZone. Body Panel Fastener. This part was a perfect fit on my bumper. You get 2 Ea/Pkg.
Hardly_Ideal
May 20, 2019 12:13 PM
honestrands
Feb 12, 2019 07:19 AM
angelonino11292
Oct 14, 2016 05:55 PM
madiiax
Jan 15, 2016 02:28 PM
hqly
Jun 28, 2010 06:48 PM
