any ideas what is making this noise?
Old Sep 4, 2016 | 07:59 PM
Blackberry Goose's Avatar
2010 Sport
190K
Old Sep 4, 2016 | 08:59 PM
ezone's Avatar
Sounds like something that is rotating at the speed of a wheel going around and around.
Wheels/tires/brakes?
Is the noise present only while using the brake?
Actually the sound reminded me of a plastic hubcap creaking, but a sport shouldn't have steelies and caps.
Old Sep 4, 2016 | 09:04 PM
No when going low speeds and using brakes I *think* Shim all out of pad maybe? Pad contacting wheel?
Old Sep 4, 2016 | 09:14 PM
ezone's Avatar
Figure out which corner it's coming from, pull the wheel off and check it all out.
Pad shims, backing plate, slide pins, abutment clips out of place.....?
It didn't sound like a wear indicator squeal, but I suppose anything is possible. Dig in and see what's up.
Old Sep 5, 2016 | 12:31 AM
Do Fits have the dust shields behind the rotor like some other Honda's have? I wonder if that's what it is
Old Sep 5, 2016 | 08:47 AM
Alco RS-1's Avatar
Yes, jack up one wheel at a time, spin it by hand and listen.
Old Sep 5, 2016 | 12:43 PM
jacked it up, spun wheel, heard something..touched lug nuts...3 of 4 spun in my hand
doh
Dropped down jack, torqued to 80 ft pounds..test drove...noise gone
Boy..sort of embarrassing thats what it was lol
Thanks for the replies guys
Old Sep 5, 2016 | 01:10 PM
ezone's Avatar
doh
Who was the last one to put a wrench on those lug nuts?
That's a serious liability problem.
Old Sep 5, 2016 | 05:58 PM
gkitf16's Avatar
Yikes!�� Hope that didn't put gouges in the wheel studs. You are quite lucky and attentive to trace that down fast before it came off at speed and caused a wreck. Def torque to spec BY HAND, no tire shop air guns! They seldom care and can be gorillas with those things.
Old Sep 5, 2016 | 06:28 PM
ezone's Avatar
The wheel and lugnuts can suffer damage too.
Mechanic shop air guns are A-OK!
The people who can't be bothered to do it right are the ones who cause the most damage, and it sure seems like they can be found in just about any shop.
An air impact gun can be used without damage, and get the torque right.
Old Sep 5, 2016 | 10:26 PM
indeed. couldve seriously got yourself and others hurt.
Old Sep 6, 2016 | 09:42 PM
It might have been Town Fair Tire...I'm not 100% sure
I usually will hand torque the lugs on all my cars after a rotation, bad on me for not following up like I should have.
Life gets busy and you forget the little simple stuff at times. I won't make that mistake again.
The studs look good save one that is missing some threads at the beginning. The nut does have enough threads to grip onto for a nice tight fit (when it's done right lol) That has been that way for awhile though. Eventually I'm going to have to replace it...afaik replacing a stud is not all that intensive to do?
Thanks for the advice guys...it's running as good as new now...I expect another 190K out of it
Old Sep 6, 2016 | 10:17 PM
ezone's Avatar
Have the shop take care of the damage caused by their error (good luck with that)
It may not be simple to replace a wheel stud on your own:
https://www.fitfreak.net/forums/2nd-generation-ge-08-13/94073-trying-rotate-my-hub-so-i-can-take-wheel-studs-out.html
Old Sep 8, 2016 | 09:23 PM
Yeah no...lol I'll have the dealer someone else put in new wheel stud. Somethings I can tackle, that ain't one of them
rutterhups
Jan 24, 2018 08:00 AM
plee82
Dec 14, 2015 11:33 AM
narnold
Jan 8, 2015 07:50 AM
Lobo1101
Jun 3, 2014 06:02 PM
single_digit
Feb 14, 2013 11:56 AM
