Alarm goes off when using key to open door and can't be silenced?
Old Sep 11, 2016 | 02:53 PM
Flyboybob's Avatar
The battery in my key fob finally died on my 07 Fit Sport. When I tried to open the door using the key, the alarm went off continuously. Luckily I was at home and used the spare key fob to turn the alarm off. I looked in the owner's manual and there is no reference to a security system only reference to the mobilizer and the panic button.
How do I stop the alarm if I try to open the door with the key? Also, will just replacing the battery in the key fob require any special reprogramming?
Thanks in advance.
Old Sep 12, 2016 | 02:51 AM
ezone's Avatar
There should be a 3 wire switch attached to the key cylinder, I'd suspect it needs checked.
Fob battery: just replace it and it should work again.
ophrey
Jul 13, 2014 01:26 PM
john21031
Dec 18, 2009 01:57 AM
wootang00
Dec 3, 2009 02:31 AM
oneduduboy
Dec 4, 2007 12:07 AM
Luichenwai
Apr 20, 2007 08:26 PM
