3rd Gen GK Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 3rd Gen GK Honda Fit
Weird Noise After Installing Curt Tow Hitch
Old Oct 13, 2016 | 01:50 PM
Peterjens's Avatar
I installed a Curt Tow Hitch after reading posts here. After the install, I now hear a "tinny" sound coming from the engine area when driving at a crawl speed of around 5 mph or less. The sound doesn't have a rhythm, i.e., pattern. I was wondering if it has something to do with the muffler as it was unsupported for a time during the install.
I am at 15% (Minder) so I haven't taken the 2015 EX CVT in yet. The stealership wants me to charge me $133 for analysis.
Any thoughts on what it might be?
Old Oct 13, 2016 | 02:23 PM
Bassguitarist1985's Avatar
In the engine bay, no idea. The heat shield of the muffler will rattle if the hitch isn't installed properly. I don't trust CVT's to tow anything period. At least with the 6MT you got actual metal gears between the motor and wheels.
Old Oct 13, 2016 | 06:52 PM
Peterjens's Avatar
I installed the tow hitch just to transport landscape clippings to the refuse area with the HOA trailer. Nothing major - real light use.
I'm talking ferns and flower petals. I made sure the muffler guards in the back end weren't touching the hitch (as advised by previous posters).
In a perfect world I would have a floor jack and lift up the front end and engage the Drive to isolate the noise. Just hoping it had happened to someone else. I know it is something pertaining to the hitch installation because the noise was not present pre-installation.
Old Oct 13, 2016 | 11:02 PM
Yeah i got nothing. Hitch on the rear of the car and noise in the front, dont make sense to me.
Old Oct 14, 2016 | 07:38 PM
DrewE's Avatar
If it's an exhaust heat shield, it probably would rattle when you rev the engine slightly in neutral/park. If so, you might be able to locate it with another person by having one rev the engine and the other figure out where the sound is coming from. I would suggest trying that when everything is cool, particularly if you're about to poke around the exhaust system. It also wouldn't be a terrible idea to chock the wheels.
Old Oct 14, 2016 | 09:45 PM
Chopper's Avatar
From: SE Mn, Even Jack Frost Moved up North was to cold for him :-)
I put mine on about a month ago, I would check the rubber grommets on the rear muffler, make sure they are seated, I siliconed mined so they slide on better, give the whole exhaust a good pull push, I put mine up on jack stands on the rear for the install.
Old May 25, 2020 | 05:37 PM
Jazu's Avatar
Did you ever figure out why your car rattled after installing the Curt Hitch?
Old May 26, 2020 | 09:12 PM
rla217@'s Avatar
Maybe it is the mufler heat shield, and the exhaust pipe is just transmitting the sound to the engine bay, like a telephone wire.
hoopmatch
May 24, 2019 08:23 PM
max503
Jul 14, 2017 04:52 PM
SilverEX15
40
Jun 1, 2015 02:20 PM
BlueBoogers
Apr 7, 2012 09:45 PM
fittr9
Apr 12, 2010 03:15 PM
