Rear Hatch Compatability
Old Dec 3, 2016 | 03:31 AM
mistrfit's Avatar
Can anyone tell me if a 2009 sport model rear hatch will work on a base model Fit? I need to replace my hatch and have found a used one from a sport model with no rear key hole. Thanks
Old Dec 5, 2016 | 09:00 AM
arrow_runner's Avatar
I'm using a sport hatch on my 09 base, so yes. You can buy an oem keyfob for cheap and use that as well.
Old Dec 5, 2016 | 02:08 PM
mistrfit's Avatar
Thanks
Thanks for the confirmation. I assume there would be other modifications required other than getting the OEM key
fob correct?
Old Dec 5, 2016 | 02:10 PM
You'll probably need to adjust the strike plate/latch/whatever it's called. If you still have your old hatch, strip everything off of it in case you need it. There might be something you'll need to do so the door ajar light doesn't stay on, I forget.
Flyboybob
Jun 26, 2022 09:15 AM
BMCBoid
Mar 5, 2016 10:25 AM
deevergote
Jan 2, 2016 08:55 PM
martyirish
Mar 25, 2013 07:55 PM
chadew
Aug 28, 2011 01:01 PM
