Check engine light??
Old Apr 1, 2017 | 05:24 PM
Sconner2127's Avatar
Hey everyone I'm new to this forum. I have some questions to see if anyone could lend some advice. We have a 2009 Honda fit sport. It runs good but then when you get to a 1/3rd of a tank of gas. The check engine light comes on. I ran the codes and the only ones it gives me is misfires on cylinder 3. I changed all the plugs, the coil and wire. It still keeps giving me that code. It doesn't lose any power or anything. I am at a complete stump. Any help will be greatly appreciated.
Old Apr 1, 2017 | 07:31 PM
ezone's Avatar
Is this a consistent and repeatable issue?
Have you received this same fault code each time the event occurs, or is this the first time you've actually checked fault codes after an event?
Have you picked the correct cylinder to work with? I often see posts where people mis-number their cylinder order.
Wire? What wire?
Valve clearance adjustments done yet?
Swap injector with one from a different cylinder, see if the misfire code moves and follows to the swapped position?
Old Apr 2, 2017 | 12:26 AM
dwtaylorpdx's Avatar
In my experience besides the typical, plugs, coils valve adjust,, if you get a misfire at a lower tank level its usually fuel filter and or pump.
angus.mundy
Dec 15, 2024 12:16 AM
mk2007
Aug 8, 2024 01:57 PM
fr8train
Feb 1, 2016 07:26 PM
gfrobe
Jul 25, 2015 10:08 AM
MikeSwope
Oct 25, 2013 12:15 AM
