2007 Fit Sport, Antenna repair
Old Apr 13, 2017 | 03:23 PM
clearesammich's Avatar
I recently bought a 2007 Fit sport, and it came without the antennae. Or so I though. Apparently the previous owner had broken it off inside the mount, so when I went to replace it the antennae would not go in fully. (Pictured)
I was wondering what the easiest way to get that part of the screw out.
Old Apr 13, 2017 | 03:40 PM
xxryu139xx's Avatar
maybe use one of those tap out screws that u use to drill out broken screws
Old Apr 13, 2017 | 04:47 PM
I though of that too. But I'm curious if the antennae holder comes off, and does the screw hole go all the way through. Because it would be a lot easier to push it through them to pull it back out.
Old Apr 13, 2017 | 05:12 PM
xxryu139xx's Avatar
Well. To remove the antenna base, you need to drop the headliner a little bit. Remove the weather seal rubber. Remove the child seat clip panel. Detach your C pillar trim. Then drop the headliner. There is one screw holding the antenna base.
I doubt there is a hold through it to do all this just to find out. Water isn't supposed to go thru there. But hey, the guy may have damaged the antenna base anyway.
Iridium
Oct 27, 2017 04:33 AM
JehovahsFitness
Oct 15, 2016 08:20 PM
SilverEX15
Sep 28, 2014 09:26 PM
tgr23
Dec 16, 2013 04:57 AM
bobthenuke
Apr 17, 2007 04:57 PM
