Firewall grommet hole - Can I use this for power cable?
Old May 12, 2017 | 08:04 PM
ck42's Avatar
Needing to install amp power wire.
Right below the clutch pedal attachement to the firewall, there's a grommet. Removing this just shows something like a 5/16" hole that is only about a 1/4" deep and then hits metal.
If I drill this out, will it provide access to the engine compartment (w/o damaging anything in the process?
Here's what I'm referring to
2010 M/T
Old May 12, 2017 | 08:15 PM
Action Jackson's Avatar
Not sure about the GE, but with every car that I've owned, I routed the power wire with the large, common wire bundle through the firewall. Then I just re-taped everything.
Old May 12, 2017 | 08:22 PM
xxryu139xx's Avatar
if u look above that area is the said wire bundle. u can use that.
GSX600FMAN
Jul 3, 2017 06:43 AM
Shravan S. Dwarka
Mar 19, 2017 07:25 PM
GotFitB13
41
Mar 17, 2015 07:30 PM
12vltfrk
Sep 30, 2009 08:10 PM
krissnkev
Jun 6, 2008 04:18 PM
