Wheel question for a 2015 LX
Old May 18, 2017 | 12:36 AM
p1co's Avatar
Lightbulb Wheel question for a 2015 LX
I understand factory wheel offset is +53mm for the stock wheels on the gk. I'm trying to gauge whether +42mm offset would work on my 2015 LX.
I'm eyeing the Touren TR9 3190 (3190-7701MB) and would like to know if it's going to give me any problems if I put 205/40R17 tires on it.
Bolt Circle: 4 x 100mm/4.5"
Offset: +42mm
Hub Bore: 67.10mm
I'm interested in getting the wheel as flush with the fender as possible, with a +42mm offset, is that going to be a difficult task? I'm not really sure how far out I can safely distance a wheel from the hub.
Any guidance would be appreciated, thanks!
Old May 18, 2017 | 01:38 AM
Rob H's Avatar
Offset: +42mm
Hub Bore: 67.10mm
Yes, I'll help. Offset is useless without wheel width.
Offset = the distance the mounting face is "offset" from the centerline of the wheel.
So for example two wheels have the same offset, yet one wheel is 6" wide and the other is 8" wide. The 8" wide wheel will now be 1" closer to the strut and poke out 1" further to the outside of the car than before. Get it?
You can do the research for the OEM wheel width, what the width of the wheel you want to buy or fit is and then the math.
Old Jun 4, 2017 | 01:06 PM
p1co's Avatar
Is 2mm less clearance to towards the strut something to worry about?
Old specs and new specs compared
Old Jun 4, 2017 | 01:50 PM
Hootie's Avatar
You'll be closer to flush... I'm not entirely familiar with wheel clearance on the current GK5 Fit to be honest; however, you should be ok up front since Fits can usually stuff a decent amount of tire up front. The rear MIGHT have minor rub on hard bumps especially if you use a 205/45R17 (closer to factory tire size in terms of outer diameter) instead of the 205/40R17 (smaller OD and closer to the GD3's factory size).
Using an EX wheel as a guide point...
185/55R16 vs 205/40R17 with your wheel choice.
185/55R16 vs 205/45R17
Old Jun 4, 2017 | 02:14 PM
p1co's Avatar
Wow, that's a wealth of info, thanks!
Old Jun 12, 2017 | 02:25 PM
p1co's Avatar
Thanks for the advice Hootie & Roh H.
205/40ZR-17 Riken Raptor ZR RF's on some Ninja NJ02 17x7 wheels.
Before
After
Mooser1454
Sep 25, 2018 05:01 AM
Blueputtputt
Apr 29, 2010 12:55 AM
Korywithak
Nov 25, 2008 12:58 AM
m-man@sbcglobal.net
Oct 28, 2008 01:56 AM
FireFit
Sep 13, 2006 03:38 PM
