Would 16x7 6mm offset
Old May 27, 2017 | 08:03 AM
mikeGe82012's Avatar
Hey I'm thinking about getting set of wheels that are 16x7 with an offset of 6mm planning on running them with either 205/55 or 205/50...will this spec for on a ge8??
Old May 27, 2017 | 11:54 PM
shinjari's Avatar
a 6mm offset? The OEM offset is something like +55. You will definitely need a serious roll and pull if you're trying to run 6mm.
People running 7" wide wheels with +35 offset is pretty flush front. So 35mm - 6mm...would mean your wheel would stick out past the fender by 29mm (> 1")
I'm running 8" +35 and I have like 6mm of poke in the front which camber fixed, but pretty flush in the rear.
Old May 28, 2017 | 12:11 AM
xxryu139xx's Avatar
i think for 16x7, the rear offset max would be about +35 and the fronts are +42. i would have some big time poke.
EMC2
Apr 29, 2024 12:20 PM
08_vbp_fit
Dec 16, 2016 01:56 PM
linnboi
Jul 20, 2012 12:43 AM
sbualuba
Jan 31, 2009 02:04 PM
SYMBIOTIX
Mar 14, 2008 08:05 AM
