HELP: Wiring of the 2nd Fit
Old Jun 11, 2017 | 11:00 PM
kaka19830's Avatar
Question HELP: Wiring of the 2nd Fit
Hi guys, My 09 Fit is a basic model without remote keys. I am fixing an aftermarket central power lock system. But I face some problems here, how can I wire the power cable through the firewall to the battery? The other side of this cable is connected the door lock control unit in the cabin.... And the control unit also needs to connect the turning signal positive, where are these turning signal wires located? Thank you for your information!
Old Jun 13, 2017 | 01:05 PM
shinjari's Avatar
Welcome to the forum.
When doing my AMP install, which required power thru the firewall there is a large grommet above the gas pedal. Check out this thread for pics.
https://www.fitfreak.net/forums/2nd-...stall-log.html
Why does a door lock controller need to connect to the turning signals? Is that simply to flash the lights to indicate that you locked or unlocked it?
Old Jun 13, 2017 | 05:41 PM
kaka19830's Avatar
Thank you, yes, it indicates that whether doors are locked or unlocked... shown as this video, but this car is not a Honda FIT.
Old Jun 13, 2017 | 06:17 PM
shinjari's Avatar
I would check the fuse panel under the driver side, you could possibly even find a 12v to tap in to there. Locate the turn signal fuse and source the wiring from there. A multimeter will help. =)
I'm trying to locate an electrical diagram but the firewall here at work prevents a lot of image sharing services.
Old Jun 14, 2017 | 03:26 AM
kaka19830's Avatar
If I pull the power cable from the engine bay, I think that I should remove the air box and/or battery first...
Old Jun 14, 2017 | 05:16 AM
Black3sr's Avatar
The plug with the blue and pink wires are for the signal lights.
Old Jun 14, 2017 | 08:24 PM
kaka19830's Avatar
Thank you, I unplugged this connection and turned my car on. But the turn signals are still working...
Old Jun 15, 2017 | 07:08 AM
Black3sr's Avatar
Interesting. Still those are the wires you would need to connect to no?
Old Jun 15, 2017 | 06:06 PM
kaka19830's Avatar
Yes, It can show whether doors are locked or unlocked... I will try to figure out where turn signals positive located... Thanks..
Old Jun 16, 2017 | 07:44 AM
2ndFit's Avatar
I only get wired if I drink a lot of coffee.
banjodog
Feb 21, 2016 12:39 PM
Joey Tuller
Nov 22, 2013 08:38 PM
gold-civic
Jul 4, 2013 02:34 AM
12vltfrk
Sep 30, 2009 08:10 PM
impreza
Feb 11, 2006 01:33 PM
