08 Fit AC Condenser Fan Clip
Old Jun 18, 2017 | 08:35 PM
RandomKoko's Avatar
I'm trying to replace my ac condensor fan, but this blue clip won't come out, are there any way to remove this clip? Thanks
Old Jun 19, 2017 | 12:47 AM
ezone's Avatar
I can see the tabs on the back side of the clip are exposed, squeeze them together with needle nose pliers while pulling or prying on the clip.
Or just pry the damn clip off of the shroud by force....You can surely secure the harness with a zip tie later on?
Old Jun 19, 2017 | 05:52 PM
RandomKoko's Avatar
I tried it, but it was too big to get into the clip. Any one else has an experience with these?
Old Jun 19, 2017 | 08:05 PM
ezone's Avatar
Get the shroud free and pulled away enough to get behind the clip with pliers
Or just pry the clip out of the plastic shroud and don't worry about ruining the clip, you can zip tie the harness in place when you reassemble.
Old Jun 20, 2017 | 12:34 AM
dwtaylorpdx's Avatar
The wire unplugs frm the harness the clip stays on shroud ,, at least on my GD.
scarvalho
Oct 26, 2020 11:50 AM
kakrohn
Aug 31, 2020 04:13 PM
Loganlecain91
May 2, 2019 11:21 PM
climbgunks
Jun 13, 2015 06:50 PM
