Anyone know of a fuse that only has power when ignition/car is OFF
Old Aug 9, 2017 | 03:29 AM
Macswfc's Avatar
I'm thinking about having some led lighting come on ONLY when the car is off. Just wondering if anyone knows a fuse location off the top of their head? Or an alternative method of achieving my goal...short of a switch.
Old Aug 9, 2017 | 09:03 AM
James Butler's Avatar
I would get a 12 volt DC relay and wire it to turn on with the ignition circuit. Hook your LEDs up using the Normally closed contacts. When the car is running the relay turns on and cuts power to your LEDs. When car is off so is the relay and now LEDs light up. I would add a switch to turn off LEDs manually so the battery would not run down of you leave the car for long periods.
Hope that helps
James
Old Aug 11, 2017 | 04:57 PM
Macswfc's Avatar
Hope that helps
James
Good idea, thanks.
Macswfc
Dec 31, 2015 08:00 AM
Macswfc
28
Sep 3, 2015 04:00 AM
SilverEX15
Aug 6, 2014 08:09 AM
stock0891
Jan 28, 2011 04:27 PM
B-Fit
Jul 19, 2008 11:02 AM
