12 Volt Outlets
Old Aug 5, 2014 | 03:12 PM
SilverEX15's Avatar
12 Volt Outlets
I'm surprised that a modern car with so much electronics has only two 12v outlets. I have a GPS, XM radio, DashCam, and cellphone charger. What I usually do with my cars is add a separate fuse block wired directly to the battery and located above the driver's feet. From that, I can run wires to whatever I want.
So, two questions. Does anyone know a good place to run a wire from the battery through the firewall into the car? How about some good locations for extra 12v outlets?
I also have a set of variable-color LED strips to put under the seats and the dash.
Old Aug 6, 2014 | 07:35 AM
DWils's Avatar
What about an add-a-circuit so then you don't have to worry about going through the firewall and you can tap into a fuse that suits your needs based on ignition switch position.
Old Aug 6, 2014 | 08:09 AM
SilverEX15's Avatar
I thought of that, but I like having four new fuses available. I haven't gotten under there to look for an empty fuse slot.
SilverEX15
Feb 12, 2019 07:25 AM
SilverEX15
Aug 25, 2014 08:29 AM
stock0891
Feb 20, 2010 04:06 AM
bikethis
Sep 27, 2009 03:12 AM
Neil-in-Arizona
Aug 11, 2009 04:31 PM
