Location of clutch bleeder screw?
Old Sep 2, 2017 | 10:21 AM
specialgreen's Avatar
I'm looking for the clutch bleeder screw on a 2007 base Fit. I think I found it along a pressurized metal tube on the front-side of the engine, just aft of the lower radiator hose (which has a yellow paint marking at about the right spot):
https://www.dropbox.com/s/oyhklvg2ed...85358.jpg?dl=0
HTTPS://www.dropbox.com/s/r2kua3ppy2...85352.jpg?dl=1
Old Sep 2, 2017 | 11:40 AM
ezone's Avatar
Clutch bleeder is ON the body of the clutch slave cylinder.
It may or may not have a rubber dust cap on it.
Same bleeders as used on the brakes.
Old Sep 2, 2017 | 12:27 PM
Thanks. I follow the fluid from the reservoir, through a pressure hose down to a round thing mounted on the driverside wheel well firewall, a bit smaller than a hockey puck, which I think is the master cylinder. That has a second hose which transitions from rubber to metal a few inches away, and travels to the forward side of the engine. There, I think I see the slave cylinder. It looks like this:
Duralast Clutch Slave Cylinder CS2619 - Read Reviews on Duralast #CS2619
except that where the accordion rubber boot is in the photo, mine has a huge rubber shroud (almost like a sock) which turns 90 degrees and runs down to the transmission. It does have a rubber-capped bleeder valve.
Pretty sure that's it, but I couldn't find online pictures showing the exact location. I had read some descriptions of needing to remove the battery and airbox, or the coolant reservoir, but on my Fit, this is very accessible.
Old Sep 2, 2017 | 01:00 PM
ezone's Avatar
Honda parts catalog pic:
Old Aug 2, 2022 | 04:28 PM
GinoLicious's Avatar
I dunno if I’m crazy or not. But I can’t seem to locates the bleeder screw. My fluid is black and I want to change it since I have left over fluid from bleeding the brakes yesterday.
Is the bleeder screw on the front of the engine in the middle? Behind the fat ass rad hose?
Old Aug 2, 2022 | 04:35 PM
AirborneRATT's Avatar
It's item #1 in the above diagram for what it's worth.
gqcpa
Sep 23, 2018 06:04 PM
hyperfit
May 25, 2016 05:47 PM
mnapuran
Feb 25, 2016 05:58 PM
Mister Coffee
May 12, 2015 12:24 PM
cakacon
Feb 10, 2012 10:48 PM
