Pulling 12V Power from Fuse Box?
Old Sep 22, 2017 | 11:19 PM
RavenManiac's Avatar
I need to pull some power from my 2017 Fit EX to power a dash cam.
  1. Which circuit can I pull constant 12V power from?
  2. Which circuit can I pull accessory switched 12V power from?
Thanks!
Old Sep 23, 2017 | 01:27 AM
Action Jackson's Avatar
Accessory 12V switched is a 7.5 amp fuse located in the fusebox under, and to the left of the steering wheel.
For 12V constant, I hooked that up to my sound system already installed, meaning I ran power wires through the firewall in the big, common wire bundle. The grommet is located under the steering wheel against the firewall.
Old Sep 23, 2017 | 07:59 AM
Pulling power from the fusebox would be a LOT more convenient. Isn't there at least one circuit with constant power?
Old Dec 28, 2017 | 12:13 PM
simonx314's Avatar
I found a fuse slot with constant power in my 2015 Fit. See the images I posted in this thread:
https://www.fitfreak.net/forums/3rd-...ml#post1332962
Old Dec 28, 2017 | 12:58 PM
not sure why youd need constant power for a dash cam. youre going to drain the battery if ran while parked.
id just tap a switched fuse and only use while engine is running
epijimenez
Jun 28, 2014 12:00 AM
Perrenoud Fit
Sep 30, 2010 06:21 PM
benlinus
Nov 21, 2007 12:36 AM
Balorn
Jul 21, 2006 05:58 PM
John W. Barron
May 4, 2005 04:44 PM
