Check Charge System + Warning Lights
Old Nov 3, 2017 | 01:03 PM
TougeMonster_GK5's Avatar
So after a week or so installing my SiriusLed MX series bulbs, the 'check charge system' and warning lights go off intermittently. I did some research and saw this possible culprit is either bad battery or bad alternator. Before I could start troubleshooting those two components, I first replaced the lowbeam bulbs, after 2 days, the warning notice stop going off. Has anyone exeperienced anything similar? I bet the LEDs are drawing too much power off the alt/bat. Im wondering if upgrading to a 51R battery will eliminate the warning trigger given the car has 51xxx miles now. I also dont think there is a loose connection somewhere, i might be wrong! Thanks in advance FF!
Old Nov 3, 2017 | 01:46 PM
GAFIT's Avatar
Wonder if there's an internal short in one of the bulbs?
Old Nov 3, 2017 | 05:41 PM
hasdrubal's Avatar
Don't know what to tell you, I have the same bulbs as you and no problems.
Old Nov 4, 2017 | 03:19 AM
Action Jackson's Avatar
Last time I saw that charge system message, I replaced a blown fuse to my horns, disconnected the battery monitor connector (that's connected to your negative battery terminal) reconnected and never saw the message again.
I didn't get the other warning lights that you got.
Old Nov 4, 2017 | 04:56 AM
skatana's Avatar
I’m running an older set of sirius leds and haven’t had a problem yet.
Old Nov 22, 2017 | 11:53 PM
Kevin Evans's Avatar
I doubt the LEDs would draw more power than the stock incandescent bulbs. Could take an ammeter and check the current draw of those bulbs via the fusebox.
I ran into this problem (check charge system + lights) at 50k miles.
Checked the battery and it was charging just fine. I drove it for like 5000 miles after that and it was OK. I found a $50 junkyard alternator and replaced it. Light went away.
Just last week at 90k miles had the same thing happen. Replaced it again and the light went away.
I bought the alternator for $50. New belt was like $15 from orielly's. No special tools, just socket wrenches (17mm tensioner) and sweat.
Old Nov 23, 2017 | 07:47 AM
huh, alternator only lasts 50k miles? dang.. good reason to sell the GK early, thanks!
Old Nov 30, 2017 | 12:53 PM
So just an update:
After replacing my LED bulbs for standard Halogens for two weeks, the warning lights never went off again. Now for the past week or so I put back my LED bulbs and still no warning lights. Im gonna give it a few more weeks to see if anything comes up, but now starting to wonder if it was a fluke of some sort, but interestingly enough, it did go off numerous times before.. strange, I think my GK is telling me something lol
Old Nov 30, 2017 | 01:41 PM
sounds good touge! hope it's cured.
Old Jul 25, 2018 | 11:46 PM
Mirna De Rafael's Avatar
buena noche puede explicarme como resolvió el problema gracias
2nddoorleft
Nov 20, 2018 07:06 PM
preskool
Sep 14, 2015 02:01 PM
struthiocamelus
Mar 15, 2015 09:39 PM
moolman
Nov 30, 2011 10:34 AM
Santiad
Jan 26, 2010 03:31 PM
