2008 Honda Fit Sport | Squeal while driving only
Old Nov 22, 2017 | 11:15 AM
Christina Diaz's Avatar
I've noticed a noise while driving in the past two weeks, it sounds like a slight screech/squeal and it doesn't happen when hitting the breaks. The other day I left work and as I was getting out of the parking lot going around 10-20 mph I heard the noise, to me it sounds like its coming from my left door but I can't even tell. Then I can also hear it coming from my dashboard area so it sounds like its coming from the engine. It doesn't happen when hitting the breaks, seems to MAYBE happen when hitting a bump. I really haven't found a reason as to why it happens. When it does it lasts for about 15 seconds then goes away. In my 45 minute commute home, it happened randomly about two times. I had my dad drive it for a day and he couldn't hear the noise or it didn't happen at all. Any ideas? I captured an audio clip of it, though its hard to hear it clearly it might help crack the case. (it wont let me upload so I can send it another way if I can figure that out.)
Old Nov 22, 2017 | 12:25 PM
ezone's Avatar
Brake pad wear indicator (also called squealer) trying to tell you it's due for front brakes?
Old Nov 22, 2017 | 12:37 PM
Even though this happens without me touching the breaks? I've tried tapping them over and over to duplicate the squeal but it doesn't happen. Only seems to happen when the vehicle is in motion.
Old Nov 22, 2017 | 01:34 PM
ezone's Avatar
Originally Posted by Christina Diaz
Even though this happens without me touching the brAKEs?
Yes
Have you checked the front brakes yet?
Old Nov 22, 2017 | 01:44 PM
yah most likely pad indicator.
Old Nov 22, 2017 | 02:43 PM
ezone's Avatar
Or maybe a pebble stuck in a brake.
Again, someone needs to actually do some inspecting to see what has happened.
Old Nov 24, 2017 | 10:14 AM
doctor J's Avatar
If not brakes can be an alternator belt (it tends to make noise when cold at idle)
Old Mar 20, 2018 | 03:10 PM
GQ_Style's Avatar
Squeal is usually the brake pads running low or the serpentine belt being loose. See if you can isolate the location of the sound. Does it only occur when your care moves (when the wheels rotate), or does the squeal occur when you are at standstill.
fujisawa
Jan 7, 2025 09:23 PM
Lukexbeitel
Sep 20, 2021 10:05 AM
tomsandoval
Jul 23, 2016 11:55 AM
geepondy2
Nov 26, 2012 05:54 PM
footloose
Mar 9, 2008 09:30 AM
