Has anyone tried these breaks and rotors? I am about to buy them
Old Dec 2, 2017 | 11:59 PM
Vash's Avatar
Hey just seeing if anyone heard of this brand or have any experience with them. I am debating about getting these
http://a.co/4ELYROX
OR perhaps i should just change the pads only and get this:
http://a.co/2J365XL
Old Dec 3, 2017 | 09:47 AM
Rob H's Avatar
Drilled or slotted rotors in a street car application is a horrible idea. Race car parts don't always make good street car parts. Race cars parts are routinely inspected and/or replaced. That doesn't happen on street cars. Drilled or slotted rotors will crack. Just do a quick Google search like where I picked up this photo from. If it were me, I'd replace them with solid Centric or the KNS solid rotors which have the same vein structure as the DBA slotted/drilled rotors. Actually call KNS Brakes with your needs or desired application, they are quite helpful and the prices are competitive
KNS Brakes
Old Dec 3, 2017 | 03:13 PM
Carbuff2's Avatar
I agree with Rob H that drilled rotors are prone to cracking on street cars. But, I feel obligated to point out that the 'holes' in the listing are properly chamfered (angled) which reduces the possibility of that issue.
https://en.wikipedia.org/wiki/Chamfer
Vash, do you plan to autocross or track your Fit? If not, stick with solid-faced rotors. (Our '07 still has the new-car rotors at 140K miles...still work great.)
I think that the Wagner ceramic pads you mention will do fine, and you won't spend a lot of time cleaning the brake dust off your front wheels!
I use Akebono ceramic pads on many of our cars, myself.
Old Dec 3, 2017 | 06:55 PM
Rob H's Avatar
Originally Posted by Carbuff2
I agree with Rob H
In regard to SCCA Solo/autocross; if you want to stay in the stock or street class than the rotors need to be as delivered by the OEM. Putting slotted/drilled rotors on a car that came with solid rotors will bump the Fit out of HS or H-Street where it's not competitive against the Fiesta ST or older Honda Civic SI into a faster class where its REALLY not competitive. Personally, I'd stay with solid rotors and maybe get some updated pads such as Project Mu or Stop-Tech. I've run Hawk HPS and HP+, but wouldn't recommend them. Just my personal preference.
Old Dec 4, 2017 | 07:24 AM
Carbuff2's Avatar
TOPIC DRIFT ALERT
Stay away from extreme 'performance pads' for street driving. They require HEAT to work the best...and that first stop on a cold winter's day could cause some underwear stains! (Same goes for ultra high performance tires.)
Buy a set of pads that will serve you under the conditions YOU drive.
TaubBaer
Jun 1, 2017 12:11 PM
Collin Quinn
Oct 28, 2014 02:34 PM
F'it_ImFromTx
41
Jul 19, 2009 09:23 AM
p1driftfiend
14
Dec 7, 2008 10:51 AM
slip
18
Jun 19, 2008 11:10 PM
